24 de Junio de 2018, 09:43:19 am
Autor Tema: WiFi Explorer 1.2.2 [CAS] [K'd]  (Leído 3029 veces)
Desconectado diego10
  • Premio
  • Reputación: +2179/-1230
    • Distributed WPA PSK auditor
« en: 16 de Abril de 2012, 12:03:32 pm »
WiFi Explorer 1.2.2 for Mac OS X‬
http://sites.google.com/site/osxwifiexplorer/
http://itunes.apple.com/us/app/wifi-explorer/id494803304
Scan, find, and troubleshoot wireless networks
WiFi Explorer detects and displays the information of  802.11a/b/g/n wireless networks in the 2.4 and 5 GHz bands. In addition, it supports 20 MHz (narrow) and 40 MHz (wide) channel widths.
Quickly identify channel conflicts and overlapping
Wireless networks transmit their signal in a narrow radio frequency range called channel. In actual wireless communications, the transmitted signals of adjacent channels will overlap and interfere with each other, and therefore you should always pick a channel that is free from other Wi-Fi routers or sources of interference.
WiFi Explorer can help you to identify channel conflicts, overlapping and other factors (e.g. configuration issues) that may be affecting the connectivity, security and/or performance of your wireless network in homes, offices, and other sites.
WiFi Explorer Runs in Snow Leopard and Lion.
http://www12.zippyshare.com/v/82853642/file.html
Desconectado marmacan
  • VIP
  • Reputación: +4/-0
  • Nada es Imposible para el que cree
  • awards Usuario con más de 100 Posts! Miembro VIP Usuario Registrado
    • Computación Berisso
Re:WiFi Explorer 1.2.2 [CAS] [K'd]
« Respuesta #1 en: 16 de Abril de 2012, 12:17:45 pm »
;D
En conclusiín segín lo que leí­ y pude traducir  debo estar ya pensando en comparme una MAC jeje  :Pporque virtualizar un sistema en otra PC no creo que sea factible que opinas Diego?
Alimento mi mente para alcanzar lo que no veo. Creyendo en el derecho de que es de mi propiedad y que merezco obtenerlo, porque lo que viene Nadie me lo quitarí¡.
NADA ES IMPOSIBLE AL QUE CREE
  • Premio
« Respuesta #2 en: 16 de Abril de 2012, 01:44:24 pm »
yo virtualizo el PC para conectarme a internet
despues comparto esa conexion con mi MAC usando bridge
la MAC no siente ningun esfuerzo utilizando ese procedimiento
todavia tengo el 95% del procesador disponible (uso el kernel en 64-bits)
Ahora no se como sera virtualizar a la inversa...
Creo que te seria mejor transformar el PC en hackintosh
antes de que sea tarde y explote todo por los aires...  :P
