EasyUbnt 5.5 Pro (Para Android)
Publicado por D3M0N, 27 de Julio de 2013, 03:34:32 PM
Descripción
Absolute must for wireless ISP providers running network on Ubiquiti Networks gear! EasyUbnt can connect to any device with AirOS operating system (Nanostation, PowerStation, Nanobridge, Airgrid, Rocket, Bullet, Picostation, Powerbridge, ..) and setup them completely from your Android device. No need to take your laptop with you anymore.
Moreover it has some professional and unique features which are not in the AirOS web interface. You can try online speedtest (shows instantaneous device speed), voice signal navigation, continuos site survey, encryption key database for your whole network and many other unique tools for wireless professionals!
This version supports all AirOS versions up to 5.5 and all AirOS 3 and AirOS 4 devices. It may also work with version higher than 5.5 (depends on future changes in AirOS system).
Novedades
* New fast configuration backup
* Now it's possible to enable voice signal strength navigation by default
* New automatic device configuration save after connect
* Current data speed for each station in Connected Stations! You can now detect who transmit most data over the device.
* Site survey now supports exports to CVS/HTML file or Email
* New site survey alignment screen. You can align your device to any network from site survey without connecting to the network.
Para Comprar: You are not allowed to view links. Register or Login
Para Descargar: You are not allowed to view links. Register or Login
