Mikrotik RouterOS v6.0 (Estable) [2013-May-20]
Publicado por D3M0N, 22 de Mayo de 2013, 09:05:15 PM
Después de muchas betas y revisiones Mikrotik liberó la versión estable de RouterOS v6.0:
Paquetes de UPGRADE
MIPSBE: You are not allowed to view links. Register or Login
PPC: You are not allowed to view links. Register or Login
X86: You are not allowed to view links. Register or Login
MIPSLE: You are not allowed to view links. Register or Login
TILE: You are not allowed to view links. Register or Login
Cambios:
* ipsec - added /peer passive option which will prevent starting ISAKMP negotiation
and signifies xauth responder/initiator side;
* RouterBOARD - default wireless config now includes password - serial number;
* lte - support YOTA WLTUBA-107;
* console - fixed crash when variable name was not specified for
* hotspot - added mac-cookie login method; You are not allowed to view links. Register or Login
* lcd - show a message when system shutdown is complete;
* lcd - added Log screen which is accessible through the Main Menu and shows log messages where action=echo;
* ipsec - added pre-shared-key-xauth and rsa-signature-hybrid authentication methods;
* increased max l2mtu on CCR to 10226 bytes;
* fixed crash on RB1200;
* fixed bonding - did not work after remove, undo;
* fixed queues - router could become unresponsive when configuring queues;
robermgs
para que es esto?
@robermgs es el sistema operativo interno que traen los equipamientos Mikrotik; el cual también se puede utilizar en una PC como para crear un router con la misma.
