Mikrotik RouterOS v6.1 (Mejorando Errores)
Publicado por D3M0N, 07 de Junio de 2013, 08:18:03 PM
A los miles de horrores que se encontraron de la ultiva version de RouterOS v6.0 tenemos algunas mejoras. (aun NO disponible en la seccion "Downloads" de la pagina de MikroTik).
Que es lo nuevo en la v6.0: You are not allowed to view links. Register or Login
Cambios v6.1:
What's new in 6.1 (2013-Jun-12 11:50):
*) pptp, l2tp - fixed crash when tunnel mru was too big and fragmented ip packet
   was received;
*) hotspot - fixed problem when after upgrade hotspot html directory was empty;
*) ipv6 nd - dns dynamic-servers were not included in router advertisements;
*) winbox - fixed problem Switch menu disappeared on RB2011;
*) fixed memory amount issue on RB1100AHx2;
*) console - '/import' prints each command that is executed;
*) console - 'import' has new argument 'from-line' that starts executing
    commands after specified line;
*) secure api - fixed problem when wrong client ip address was reported;
*) hotspot - fixed universal client;
*) api - added support for API over TLS (SSL);
*) api - api service is now enabled by default;
*) ppp - do not show R flag for locally authenticated users;
*) vrrp - fixed ah authentication;
*) webfig - added support for RADIUS authentication (via MS-CHAPv2);
*) ipsec - for peers with full IP address specified system will
   autostart ISAKMP SA negotiation;
*) trafficgen - added inject-pcap command for replaying pcap files into network;
*) dns - retry queries with tcp if truncated results received;
*) improved queue statistics updating;
*) fix 1G linking with some Cisco devices (affects RB7xx, RB9xx, RB1100, RB2011, CCR);
Les pongo todos los links para su descarga:
CCR: You are not allowed to view links. Register or Login
PPC: You are not allowed to view links. Register or Login
MBE: You are not allowed to view links. Register or Login
MLE: You are not allowed to view links. Register or Login
X86: You are not allowed to view links. Register or Login
La v6.1rc1
Cambios v6.1rc1:
What's new in 6.1rc1 (2013-May-27 08:19):
Reportar Errores: You are not allowed to view links. Register or Login
