Mikrotik RouterOS v6.12 (Mejorando Errores)
Publicado por D3M0N, 17 de Abril de 2014, 12:42:01 PM
A los miles de horrores que se encontraron de la ultima versiones de RouterOS v6.x tenemos algunas mejoras. (disponible en la sección "Downloads" de la pagina de MikroTik).
What's new in 6.12 (2014-Apr-14 09:27):
*) l2tp - fixed "no buffer space available" problem;
*) ipsec - support IPv4 over IPv6 and vice versa;
*) pppoe - report correctly number of active links;
*) updated timezone information;
*) many fixes for CRS managed switch functionality -
   particularly improved VLAN support, port isolation, defaults;
*) added trunk support for CRS switches;
*) added policing support for CRS switches;
*) www - added support for HTTP byte ranges;
*) lte - provide signal strength using snmp and make 'info once' work in console;
Descarga:
MIPSBE: You are not allowed to view links. Register or Login
MIPSLE: You are not allowed to view links. Register or Login
PPC: You are not allowed to view links. Register or Login
TILE: You are not allowed to view links. Register or Login
