WPSCrackGUI
Publicado por jaladhjin, 05 de Enero de 2016, 06:20:27 PM
jaladhjin
So it seems AirUbuntu has been called an outdated distro..
Do you recommend any preferably live distro with WPSCrackGUI installed stock & ready to go ?
The only one I've tried that supposedly had it was Wifislax but when I click on it nothing comes up..
I'd prefer to use in a VM & do have the external card needed..
may not have gambas3 wifislax.
jaladhjin
can I install things if I'm using the live version ?
I thought installing things on the OS required me to install fully on an actual system..
How would I go about installing gambas3 on the os running live in VirtualBox ?
Fitap
Here you are
Please read it, may be you found out.
jaladhjin
Here you are
thank you :-)
so it seems maybe it's an issue with Wifislax.. I'll take that up with them..
I put some gambas3 commands into the terminal & a nice little window with a ui came up so I believe gambas is available.. not sure why wpscrackgui won't load :-(
Since AirUbuntu is said to be an outdated distro..
Is there any other live distro with wpscrackgui available immediately on boot ?
Fitap
thank you :-)
Sorry dude, learn english good is my nigthmare!
I think any distro live cd after boot you can download and install a lot of software what you need, In my case I don't know what is Gambas, intresting, and reading about it I find out some articles may be you must read it.
I hope this resolve your issue.
