AYUDA Mikrotik hAP Lite ......
Publicado por diego10, 03 de Marzo de 2017, 02:40:29 PM
me trabe en ether1-gateway
aviso que ether5 no tengo
y configure dhcp server para 11.11.11.11
pero me asigno IP en el rango de la otra WAN 22.22.22.xx  ;D
algo me salio mal. que sera /caps-man interface y otras extrañas lineas ???
/interface bridge
add name=Bridge-Lan
/interface wireless
set [ find default-name=wlan1 ] comment=WIFI
/interface ethernet
set [ find default-name=ether1 ] comment=WAN/LAN
set [ find default-name=ether2 ] comment=LAN1
set [ find default-name=ether3 ] comment=LAN2
set [ find default-name=ether4 ] comment=LAN3
/caps-man interface
add disabled=no mac-address=00:00:00:00:00:00 master-interface=none name=\
    ether1-gateway radio-mac=00:00:00:00:00:00
/interface wireless manual-tx-power-table
set wlan1 comment=WIFI
/interface wireless nstreme
/ip pool
add name=dhcp_pool0 ranges=11.11.11.1-11.11.11.10,11.11.11.12-11.11.11.254
/ip dhcp-server
add address-pool=dhcp_pool0 disabled=no interface=ether1 name=dhcp1
/interface bridge port
add bridge=Bridge-Lan interface=ether2
add bridge=Bridge-Lan interface=ether3
add bridge=Bridge-Lan interface=ether4
add bridge=Bridge-Lan interface=wlan1
/ip address
add address=192.168.88.1/24 interface=Bridge-Lan network=192.168.88.0
/ip dhcp-client
add comment=WAN default-route-distance=0 disabled=no interface=ether1
/ip dhcp-server network
add address=11.11.11.0/24 gateway=11.11.11.11
/ip dns
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall nat
add action=accept chain=srcnat comment="default configuration"
# ether1-gateway not ready
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=ether1-gateway to-addresses=0.0.0.0
/ip route
add distance=1 gateway=ether1
[admin@MikroTik] >
Estas tirando un DHCP-Server contra otro.. si ya viene y entra por la Ether1 el 11.11.11.11 si creas un DHCP-Server contra la Ether1.. va a ser solo para la uno. Para eso esta el bridge, que une varias ethers y de ese bridge se hace el DHCP-Server dando como resultado que todas las ethers que tenga adentro formen parte del DHCP-Server.
Si hacias el DHCP-Server contra el Bridge que daba el rango de IP: 192.168.88.1/24 -2 a 254, definido en:
/ip address
si eso cambie  8)
Si todo salio bien, tendrías que tener internet... :) y aprendiste a configurar en modo router.
no tengo internet   :-[
y hay un error al cargar
add address=192.168.2.1/24 disabled=no interface=bridge-up network=192.168.2.0
input does not match any value of interface
ahi lo arregle
tengo los 2 links
a ver como bajo un torrent
anda bien!!!!!!!
pero perdi el IP de la pagina web de mis 2 TPstations  :)
es queria cambiar de vecino y aprovechar los 2 links de 12 megas
despues retoco alguna que otra cosita pero va bien
largaroooon  :)
y cruzaron el discoooo  ;D
Se esta creando antes la IP que la interfaz, mándalo después de "#CREAMOS EL BRIDGE" y ahí te lo tiene que tomar.. o manualmente.
anda bien!!!!!!!
Con que IP Entrabas a los TPStations?
Viste que era una Papota.. el que sabe.. sabe.
Los balanceos no son parejos a no ser que las dos lineas sean simetricas y de igual velocidad. De lo contrario siempre va a variar mas una Ether que la otra.
Si vas a Interfaces en la izquierda vas a ver la sumatoria en el bridge-up..
uuuu.. tengo el mismo drama que antes con WiFeamela
funciona bien el balance de 2 cablemodems clonados. uno de los pagos esta en santa fe y el segundo cablemodem clonado (el mio) es de la ciudad de buenos aires (flores)
pero cuando yo cambio de proveedor cualquier WAN por una paga por mi vecino, no importa si es fiber o speedy se cae todo el balance
sera que tendre que probar saliendo por la misma puerta de enlace?
que cagadon. quiza sea una limitacion de los ISP   :'(
voy a rifar el Mikrotik a ver si recupero algo de plata
Si cambias de rangos de IP tenes que cambiar todo el balanceo.
puede ser una limitacion de los ISP?
